I've got some free time on my hands so i've decided to start polishing my engine.
Today after reading another thread where Doctor mentioned using 1200 grade sandpaper I went out today and bought some.
Are there any suggestions/tips/warnings before I start?
What else do I need to make it shiny (and stay shiny)?
Mark
https://www.sau.com.au/forums/topic/11258-how-to-polish-engine/
When using the sandpaper on aluminium, use crc or kerosene, it will lubricate the paper giving a better finish. Then polish sanded surface with autosol, meguiars aluminium polish, or similar.
Only use the sandpaper on rough surfaces. some surfaces will polish up with just autosol or similar.
If the surface is really rough, get a coarser grade sandpaper and still use crc or kero, then work up to the finer grades.
I used a special metal polishing drill attachement (~$30) It comes with course and smooth compound polish - THe polish look a bit like a small bar of soap - You use the drill attachements to smear a whack of compund on before going to your cam covers - It's a bit of elbow grease - but far easier than wet & dry....
You can also use steel wool and autosol. But the drill attachements and compound are the best way to go.
You can get these at Auto-One, Harware house, etc.
Cheers,
I never got a good look at your engine Brendan. The first time was at Chatswood when you took me for a ride on the cruise, and the 2nd time was australia day when it was too damn hot to look at/remember anything.
Take a pic with your new camera and email it to me:
[email protected]
Doc: I only saw yours briefly about 6 months ago at burger King. Have you got a better pic of it than that original one you've already posted?
If I loose my patience with sandpaper i'll cheat and use Brendan's drill attachment trick.
Thank you.
Mark
Yeah use paint stripper first then you use the drill bits as Brendan suggested then use a bit of light sandpaper then the polish.
I'm not at home at the moment but I will post pics tomorrow evening.
The plenum can be polished to a mirror finish but you need to sand the bastard alot to get that finish. I did my inlet pipe and it took a while to get it like a mirror but it looks pretty good though.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
