selling garrett t04 turbo
has been rebuilt
comes with actuator and dunp pipe plate and dump pipe 90 degrees pipe with oxy sensor hole
bolts on to rb25 , but needs dump made up
ar, 60
compW 57
no shaft play
*prefer pick up*
price: $600
* not a xs power Xy turbo* ....is garrett, is good :D
https://www.sau.com.au/forums/topic/112858-t04-garrett-turbo/
hey ive already got a 3" dump pipe off my stock turbo but ive also still got the stock exhaust manifold. how hard will this be to bolt up. also how much boost can this turbo handle and would you be willing to let me take this to a performance shop to get it inspected before i hand over the cash. im in qld & geniunly interested
this bolts onto stock rb25 manifold it has a t3 flange which is the same as the standerd one
this turbo is right for 22 psi,
i have a to4 on my r33, n im pretty happi with it, still yet to dyno though
kicks in at 3.8
so if u dont mind the lag, n like the price, buy it :thumbsup:
"speed freak" u can get ur performance work shop to look at it, i got no dramas with that, but it have to be a sat cuz i work mon-fri at south side toyota.. cheers
it uses stock oil lines n water lines, u need new washhers thoug, t3 uses stock manifold
it ill bolt right on but u need to mod ur intake pipe, and your dump pipe
.. sorry i do not have recpcets, but inspections are welcome n if you want more pics, pm me.. i got a good cam
very interested:
So what are the parts that need doing to get this working on my r33 s1 rb25det and how much will it cost to be running. As iv never had a turbo car before so i dont know what work has to be done to putter a bigger turbo.
parts u would need is a new dump pipe, new intake pipe, 6 banjo washers, 1 oil line gasket, and dump pipe gasket,
its pretty easy it took me 2 days with limited hand tools only dramas where 1 banjo bolt on the engine side which was hard to get to and snaping bolts n studs off my old exhuast system
Edited by akkii
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
