I tried to save money as well and use the VN coils. Was to date the biggest headache I have had with the car (RB20). Not exaggerating, I melted at least 8 sets and the problem was still not found. Not to mention other little things like cross tracking, the longer leads having less power etc.
In the end we decided to give one set of AU coils a chance before rewiring and going to the splitfires. They have not missed a beat yet but in hindsight I wish I had got the splitfires.
If you are running ~1bar or more just go the splitfires and save yourself the drama.
I have tried using bosch coils and it was an expensive and fruitless exercise.
Splitfires = ~$550 delivered from perfectrun.com.au - not a miss in sight since I installed them.
Edited by Lazy-Bastard
I did the wiring myself with the Bosch coils, but still by the time you add it all up (coils = 6 x $60 + leads ~$40 + wire and connectors ~ $30 + whatever your time is worth) it ALMOST works out cheaper for Splitfires.
Add to that you don't have to find somewhere the mount the f**kers in the engine bay......go the Splitfires!
i have seen this done, the thread was on r31skyline forum.
or look here
http://gdz1la.kol.co.nz/prod01.htm
MEC717 Bosch coils but they need 3.5ms charge time and many ECUs cant do that and if your ECU can your Nissan module wont last.
Splitfires cant be beat.
So does that GDZ1LA setup run the MEC717 Bosch coils???
No it doesn't.
If anyone wants 6 Bosch MEC717's at a HEAVILY discounted price, see my for sale thread here http://www.skylinesaustralia.com/forums/in...opic=110727&hl=
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
