hey guys,
after reassembling my engine i ran some real cheap shit oil to flush out all the crap, and now i want to change it with the good stuff.
i have an extrnal oil cooler, and was wondering if the liter or so of oil still in the cooler will cause any problems?
do i have to undo the piping to drain it? or can i alet it mix with the new oil?
thanks
steve
I'd personally get rid of it myself but then again I'm not an experienced engine rebuilder. But think about it, that oil, which is a significant ammount, has a fair bit of shit in it, do you really want to keep that in the system?
Suppose you could always buy one of those 2Litre refill bottles of good oil to flush the rest out after u've drained it....Run it for 2-3min then drain that last bit out before you fill it properly....
Did that make sense???
-Drain crap oil
-Put in 2 Litre of good oil
-Run engine for 2-3min
-Drain the 2 Litres & Change filter
-Fill with good oil
-Done....Have a beer!
Edited by R33_STEALTH
hmmm, i thought about that too, but i dont know.
e.g the good oil im using is 5w60 (or something like) so would it mix up ok if i put in some gtx3 to flush out the bad oil?
whats everyone else doing??
steve
That is some pretty heavy oil you are putting in. It will actually create more wear during startup and shear rapidly with this kind of spread. Take a read on startup wear by Dr AEHaas.
Motor Oil .. Thin or Thick oil?
yeah, thanx for the link, but im using the oil reccoemened by SK him self, so let him know about Dr AEHass's site and see what happens.
Also, it 10w60 im using. I just went and checked it.
Whats everyone else with an external cooler doing???
Steve
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
