Item:
S15 200SX
Canberra, ACT
Website:
Item Condition:
Very good
Reason for Selling:
It will be a shame to see the car go but I can't justify the cost of insurance at the moment and will be looking to get more involved in entry level motorsport (Group N or IPRA). If required I can also supply a second set of standard rims with Bridgestone RE540 semis. Note that the tyres on the car are completely street legal, more information on them is on the Toyo website www.toyo.com.au.
Price and Payment Conditions:
$27,900 Negotiable
Extra Info:
Colour: Pewter (Silver)
2 litre turbocharged four cylinder
Factory 6 Speed Manual
A/C
Factory Sunroof
Factory Spec R Kit
Factory Six Stack CD player
APEXi AVC-R Electronic Boost Controller
APEXi GT Front Mount Intercooler
APEXi Power Intake Filter with box
Aftermarket mandrel bent exhaust
Lowered Springs
Roadholder Front Sway Bar (Solid 27mm adjustable bar)
Roadholder Rear Sway Bar (Solid 20mm non-adjustable bar)
Standard Wheels with 80% Toyo R888 Semi-slick Proxys (retail at over $300 a corner)
80,000kms serviced by Nissan at regular intervals
Ferodo DS2500 Brake Pads
ACT Rego till April 2007 (12 Months!)
Dyno'd at 184rwkw or 247rwhp
Its the opportunity for an enthusiast like myself to hope straight into a car that is well setup and can be driven daily (as I do) without any problems.
Pictures:
Will be put up soon...
Contact Details:
PH: 0407 202 348 Glenn
https://www.sau.com.au/forums/topic/113418-s15-200sx-spec-r-has-to-go/
  • 4 weeks later...
Just waiting for a repley to my pm but if I'm not mistaken this is my mates old car . If so it's had a good history been very looked after first owner was a nerd from Sydney's north shore .My mate Tom purchased it off him and babied it and only used it on weekends before selling it to the current owner this is going back a few years now though .
Car has no accident history what so ever one of the more genuine s15 200's for sale best of luck with it .
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
