Wrecking Nissan Skyline GTR R32 1994 model for hit trafic lights in brisbane for test drive. front damage.
please do not ask me any front parts.
engine and gearbox take off from car.
Complete set GTR brakes and discs with aftermarket brake pads.........700
Driver side and passenger side guards, very good condition, no damage.........500
17" Wheels with rubbers.......one need fix, others good.........600
Door Trims .........excellent condition.......100 each
driver side and passenger side seats and rear seats..excellent condition......1100
Complete Doors with Windows.......excellent condition.......200 each
Tein adjustable suspension.........500.............. SOLD, wait for payment.
twin kakimoto exhaust system ........SOLD, want for payment.
others....
pics not include some parts bcz it still in car, will pick my car home then take them off on 18 April.
pm me and make offer PS. I am not a wrecking house and i do not know a lot of parts name.
buyer pay postage or pick up urself or buyer arrange postage if items are too big or too heavy.
thanks
brian.
Edited by Midnight Racer
https://www.sau.com.au/forums/topic/113448-please-closed/
  • Replies 41
err.....i need:
1) passenger side window switch.....
2) passenger side boot trim
also interested in ur kakimoto twin exhaust system...but just wondering what is the pipe size of it 80mm or 95mm???
can u plz pm me the price delivered to melbourne as well as the photo of cat back plz thank u
https://www.sau.com.au/forums/topic/113448-please-closed/#findComment-2092932
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
