To get the the firewall stud u need a small drill that can rotate to work at right angles. Otherwise u can call sum1 out to do it for u, think my mate paid $125 and he had it out in 30secs. Will hav to find his number.
Hmm maybe sum1 on the forum could help out here, i know the beer currency works well! lol
ive taken most of them off, ordered a few new studs, 2.25 each, but the gasket is 130bucks!!
then only problem i have is that the stud closest to the firewall has been snapped (most likely for quite some time now, as ive been experiencing the boost creep and flatspot for quite some time now), i have no idea how im going to get a drill into that to undo it, anyone have any ideas?
Use an air drill, as someone else says, you need a right angle drill, the proper type of air drill will get in there easily. If you don't have air rent a compressor.
i have access to a air compressor and the drill does actually seem to be small enough... where can you get the drill to drill out at right angles? i might just invest in one of them
ill give it a go tomorro night, im still waiting on the studs and the gasket to come in
I use CP air tools (Chicago Pneumatic) and they do a range of miniature right angle drills. I am in England UK, so I have no idea where in Oz you can buy these, sorry.
hahah didnt realise you were form england till just now.. lol
ill have a look around the shops tomorro
i hope i can get the stud out, should i drill a pilot hole out then use an easy out with it? i dont know if the easy out will be enough, it might actually snap before it even moves the stud
ok, ive got pics when the manifold and everything is off, and now the studs have been put in, cost 60 bucks to pull out the broken studs including new studs..
regret going to nissan to order the parts though, for 2 studs, 2 washers and 2 yokes cost 27bucks, too late to cancel so i have them left hanging around for nothing.
will post pics up shortly
after all the trouble, and after breaking another stud(when i was spinning the bolt in with my fingers!!) ive got everything back together, there is no leaks or rough idling anymore.
sorry guys about pics, was in a rush to get everything done
but my boost problem is still there, now its there iff not even worse..
i tried replacing the std actuator with a adjustable N1 actuator, and it seems to have a small flatspot still, but boost still climbs, in fact it creeps from .8 bar to 1 bar still in 2nd gear, and when i change gears, it takes a long time to boost back up again.. i mean wont reach full boost for ages, and not only does it take a long time to reach full boost.... boost now then clims to 1.3bar! and no power at all, till boost drops back off to 1.0bar
its really shitting me, ive tried without any boost controller aswell..
i have a few theories/ ideas
1. when i placed on the actuator with mods, ive had to shorten the actuator arm, so that there was 1mm to pull for the end of the arm to attach to the wastegate (if you guys can understand that, otherwise in other words, for there to be tension to keep the gate closed we had to shorten the actuators arm but the shortest we could go was 1mm shorter than where the actuator was supposed to attach to the gate)
should i fix this? or lengthen the arm a bit further so the gate is slightly open?
2. could it be my CAS retarding timing?
3. could it be my knock sensor being damaged, which ive read to retard timing aswell
4. a stupidly big leak somewhere
5. the manual boost controller? (ive had a electronic one in there... did the same thing.... ive also tried to plum the line straight from the intercooler to the actuator... still did it...
6.something jamming the intake manifold..(dunno why and how but just a though as i remmber leaving a cloth in there and and pulling it back out after the engine was turned on)
it feels like its blowing air an not doing anything about it... ive sent it to two big names in tuning and performance in canberra which i will not name.. spent large amounts of money to try and fix this problem... and it is still not fixed...
can anyone help?? please
PS: with the manual boost controller i think i may be faulty, i screwd it tight, which in turn should just give me stock boost... but it infact doesnt let me boost at all, and at 5000rpm boost starts to climb.. but im going to just plumb it from the pipe to actuator to check it again
ok guys, just tried running the car without the boost controller(just pluming a line from the intercooler pipe to the actuator), power is smooth through most of the rev range, a slight flatspot at 6000rpm.. here is the thing, it starts boosting up till .7bar then creeps rapidly to 1.1bar and looks like it would keep climing if the revs didnt run out.
i guess its not the boost controller issue, and it cant be faulty..
anyone with any ideas?
ok, realised something just before, i boosted it in 5th gear from 80km/h it sits at .6bar at 3000rpm, then when it reaches 4000rpm it starts to climb right to 1 bar before the end of the rev range..
i tried it again but at 70km/h in 5th gear, it sat at .6bar and started to fuel cut!
any one got ideas.. need to sort this out asap
what causes fuel cut
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
