  • Replies 109
Got them today and fitted bout 10 mins ago!! Thanks Kez!! Here are some piccies...R34GTT auto bezel. FYI, they fit perfectly, just getting to the dash was a bit tricky...otherwise all good.
Enjoy! :D
Not a problem mate, WOW.. they look unreal in ya R34. good work :P
by the way to any one wondering all bezels and dials sets have been sent to your home!
Tho KJ is going to kill be , because his were damaged in shipping, so mike and i are sorting that out at the moment... IM SOOOO SORRY KJ.... We are working like f**kers to get this corrected.
I got a set of bezels as well, so easy to fit, and look sweet as...
once i have sorted KJs order we will start another GB, This time i will have to ask for FULL info on year mod of cars! that was a pain in the ass last time, cause dashes DO change between the years of R32s and R33s!
like big brother says.... Be sure and be concise.lmao
But yeah enjoy people....
just a warning the prices will go up $10 for items due to postage got me into the RED on this GB!!!!!
like i said to mike, i dont mind doing this for you guys cause mike helps me and i help mike! But i dont want to shell money out ,lol!
PLEASE LEAVE ME A TENDER RATING ONCE YOU HAVE RECIEVED THE ITEM\S
anyway later...
Edited by kezza
Mine haven't arrived yet - got a long way to come though!
hey jonh, i can send you the postal dockit if you want! but its no its way bro :happy:
Yeah long way alright... Didnt think i would send them to the grand old England , lol
kezza
  • 1 month later...
  • 1 month later...
Can you get these ones for Stagea?
http://www.cyberstork.com/cgi-bin/big_view...&type=color
Ive been through the cyberstork page and it says they are available for Stagea but the question is can you get those specific ones
Simon
Edited by FLYSLY
Ive been through the cyberstork page and it says they are available for Stagea but the question is can you get those spacific ones
Simon
Mate i will for sure find out all about those cool colours! that looks killer! its the newest addition to their colour range!
Will get back to you an that simon.
  • 2 years later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
