just because the map says where it it doesnt mean everyone knos where it is, im not really good with the north side/ city area so theres no need for attuide. i was just asking a question
Sorry bud, no attitude, I thought it'd be pretty easy to work out.
  • Replies 134
hey everyone, i have study the map and i hope i wont get lost (fingers crossed) but for the sake of a good cruise, can someone else take the lead as i dont want to take a wrong turn and see every other car go the other direction from me lol....
and no ending locaton has been organised.. so i guess we will go where we want on the night...
Sorry to pull guys but i cant make it. My car is sooooo not ready for next week dyno night...
I am in the process of putting it all back together atm...
The earliest i could get it into Matt Spry is next Thursday (the day of the dyno night) at 9am... So here is hoping that nothing goes wrong otherwise ill be stuck down the gold coast... LOL
sad to hear that col.... i would offer a lift, but sadly it looks like im going to have 3 people in car as it is... and i dont think 4 would fit to nicely
Serious question?
Why SAU?
whynot pulsar.org or something?
Not much stuff happens with the pulsar forums...
Just got my car back on the road after a long hiatus and wanted to take it out with some other predominantly turbo cars and have some fun.
Plus I live about 5 minutes from the airport :P
Anyway, seems like its only really Skylines so no worries anyway :(
There will be no "fun" had!
Please come say hi though.
By fun I meant checking out some nice cars, going for a drive, etc.
I ain't no FF Hoon :(
Well if I'm welcome I might pop round and say hi and checkout some of the awesome rides on here in person :P
OK, I'll answer your query
Directions for those that will use the Gateway
If you are coming from the southside using the Gateway, you need to take the East-West Arterial Road exit off the Gateway.
You then drive down to a roundabout (you need to turn right as if you were heading for the airport).
You will now go under the Gateway and you'll be heading for another roundabout.
Go straight through the roundabout (again as if you were going to the airport)...you should very soon see the DFO on your right hand side (I hope you do, as I've never been to DFO, but have seen it from the car).
Hope this helps,
Cheers,
Karen
thanks heaps mate, (smr33) which way do u think would be the easiest from the south side, im leaning towards the gateway.
Hey Col, if you need a lift I have an empty car. But I will be having a fairly early night as I start work on Friday morning at 5am.
We need your camera skills!!
PM your address if you are keen.
Dave
Gateway for sure :worship:
Paying the toll is worth it as then you don't have to stuff around with Riverside Expressway/Sandgate Road nightmare :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
