Hey guys..
Im down to two cars now..
In two weeks both cars arrive and they are both mint condition.
Now here are my options.
r32 or r33 both white, manual, and turbs with low kms. Im assured by my importer that this is the best r32 that they have ever brought in.. so im leaning towards the 32 because it will possibly be cheaper and more mods..
*buy the 32 and mod it
*buy the 33 and keep it mainly stock.
What I want to know from you guys is how much potential there is with the RB20? Or if its worth just gettin the 33 so i can have the larger displacement engine..
Keeping in mind i want to take the car through the hills.. Which will handle better stock and possibly with coil overs.
I know its hard to compare but Im stuck.. I love the shape of the 32.. but the bigger power of the RB25DET is what catches my eyes..
Alternatively If i do get the R32.. how hard would it be to convert to RB25??
Any feedback appreciated.
Michael.
Edited by Mr. iNFMS
https://www.sau.com.au/forums/topic/113879-r32-92-vs-r32-97/
Importers always say a car coming in is the cleanest they've ever imported. Judge for yourself.
Personally I'd go the r33. Although I prefer the r32 shape, you can't go past the RB25. I personally didn't like the RB20. Only downside is that it is the most popular import going around at the moment.
Check out both cars, get the one in better condition at a better price.
The importer is a family friend.. he wont sell me a shit car.. He has been looking at cars for six months for me. These are the final two..
Yeah im not really keen on the RB20 either but im not fussed.
As for being popular.. they have died off in Adelaide.. A31 Cefiro's seem to be the new rage..
yeah r32 with rb25 = great.. i used to have one
best thing to do is to buy a very ordinary r32 gts non-turbo automatic for a few grand. then buy a written off r33 gtst (with damage to only sides and rear sothat engine/gearbox etc etc are still good) for couple grand and do an engine swap.
still should be cheaper than buying an r33 and u have a better car ;p
A mate of mine has an r32 with an rb25det in it. He just called up Nissan and asked them if the r32 skyline ever came with an rb25det in it, which I didn’t and they said it did, and put it in writing. Lucky him, u can try that, cause the r32 did come with an rb25de (non turbo) so they mite not know the difference.
And as far as performance his is definitely the best of both worlds, torque of the bigger engine and light and better looking r32.
Best of luck
Does your mate have a photocopier? Lol..
Cheers for your input mate!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
