  • Replies 40
boost looks terrible, spiking like crazy and dropping off. nice power though, big turbo id imagine? what else is modified? air fuel ratios look nice and safe too :laugh:
what gear did they dyno it in? its weird it only makes peak power at 104kmh???
cheers
Edited by CruiseLiner
list of mods=
acl forged pistons
eagle h beam rods
balance etc
standard head and cams
stainless low mount manifold
gt3071r-sp turbo
nismo 550cc injectors
q45 AFM
full 3 inch ehauxt
600x300x80 IC
walbro pump
power fc
iridium plugs
gizzmo ebc
sard rising rate fuel reg
MV auto shift kit
the turbo is basically a single turbo 300zx exhaust housing bored out to suit the gt30 core
rated at 500 hp
the compressor housing is rather large, but im thinking the exhaust housing may still be to small to let it breathe
so 8psi actuator and 18psi target :D
at a guess haha
the bigger the difference in actuator pressure and target boost the harder the boost controller solenoid has to work, and the harder it will be for the controller to maintain. you shoud find out what spring is in it
at a guess haha
im not sure if this will help but without the solenoid conected it will run around the 13.5 psi mark
yeah so its a 1 bar actuator
so the controller has to work to maintain pressure between 14psi and 18psi
so what are you suggesting?
should i get a stronger actuator?
a better quality ebc?
or a bigger turbo?
a set of pon cams?
