  • Replies 53
hi guys,
have we got those power to weight ratio laws here in tassie like they have in n.s.w etc. ??
Hey Andrew
as Todd has already mentioned we are pretty lucky and dont have to worry about the power to weight restrictions just yet.
Obviously your not going to go and get a car that you couldn't/shouldn't drive to its potential in a day to day environment and always have complete control.
Sorta like when peeps get the bike licence, a 250 is just not good enough or powerfull enough for them as they are the next Valentino :D
So they get themselves a bigger bike and within a week they crash it, put themselves in debt cause its a right off and hurt themselves or others.
Drive your car and be safe as i dont want to go to anymore funerals this year or for the next few year :laugh:
Cheers GMB
is that the chicks who works in mortys bp??
Is she hot?
I heard that blue one was dead. I've only ever seen it under it's cover, never on the road.
Andrew: I havn't taken mine to the drags, have taken it to Symmonds though, and should be going again on the may 28th.
Edited by sav man
Is she hot?
wat time did u end up gettin there ??
How about you provide some pics of your 32 GTR, some people might know of it?
Or better yet, post some pics of that R34 you drive
Car(s): nova,r32,r34,crx
Real Name: Andrew
i'll do dat as soon as i get my comp back its in getting fixed atm...( posting from one of the school comps ) :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
