98 Nissan Skyline R34 GTT
Engine: RB25DET
Colour: Black
5 speed manual
Heavy duty clutch
Factory 2-way electric Sunroof
115,000 kms
Serviced every 5,000kms
Lowered suspension
GTR rear wing
18x9 wheels (265x35x18 rears & 235/x40x18 fronts)
Front Mount Intercooler
Factory plumb back BOV
Blitz 2 stage adjustable boost controller
Blitz turbo timer
2 x Defi recordable A pillar gauges (Boost & Oil pressure) + controller
Apexi air filter
Tinted windows
Central locking
3 point blackwire remote alarm
also includes stock nismo exaust and stock ecu
Apexi PFC (tuned last week) 200rwkw.. at .9 bar
new front bar same as pictured (not fitted)
Apexi N1 exaust (fitted last week)
$26500k negoatiable depending upon interest.
so here is the story guys.. bought this car about a month ago.. nice ride and all i wish i could keep it but im just a uni student and after spending 5-6k on it, getting it to the way i want. i have realised i just cant afford to run it, go to uni, party all night, and only work twice a week.. :)
will consider trades for other non-turbo cars + money my way.
mob 0401 842 644
Edited by mook1
https://www.sau.com.au/forums/topic/114291-fs-r34-gt-t-melb/
i've been in this car a shit load, and i love it! feels so much better after the power fc and exhaust were thrown on. and the tune is bloody awesome... drove from the city back to my house and there was almost no knock at all.
definately worth it.
btw, im assuming ur throwing in the stock ecu and exhaust? might wanna mention that. lol
Thanks but i dont want to lock myself into buying something now, so if you could sell it to someone now, no worries. Otherwise if its still for sale in a couple of months ill be hunting you down :(
Ok, sounds good. Might make a time to inspect.
Got any idea if GTT's are P plate illegal?
Show me a P plater in this scene who drives a legal car. LOL!!!
If u wanna talk power -> weight, most skylines aren't.
It's a top car mate. Go and check it out. The 34's are da bomb!
am interested been following your thread for a while, just wont have money for another month or so if its still around i will be keen
quick question - what wheels does it come with?
the gtr rim on the front looks hot have you got a full set?
i think this used to be Mean_R34's car.
http://www.skylinesaustralia.com/forums/in...howtopic=108405
nice car though. Good luck!
You're right fLipKnot, it was my car.
Wish I was in the position to buy it back!
The Mrs misses it too, but want to buy a house instead.
A great buy for the $$$ and mods. I know the car inside out. :O
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
