I'm having a little problem with the engine on my GT-R overheating. If I let it sit and idle in even mild (18-20 degrees celsius) temperature, the coolant temp almost goes through the roof and my oil temp climbs up to 110 degrees c. The current setup is a Koyo 2 row aluminum rad measuring 26" x 18" x 2 1/4" and the fan is an electrically controlled 14" fan which is much smaller both in diameter and blade size to the stock fan. However, the rad is twice as big. Would the extra coolant not keep the motor cool? If not, what fan should I find to fix this overheating problem. I think I have figured out the oil temp problem, being that I put in 0w40 synthetic which I had a bad feeling about anyway. Im changing it out after just about 200 km to 10w40 synthetic because I don't trust that lighter oil. Could the overheating also be cause in part by the lighter oil? Is it possible that I have already damaged my turbos by running the lighter oil? By the way, the motor is stock with the factory boost restrictor removed and HKS pod filters and a 3-inch Apex'i cat back exhaust. Also, I am getting a stumble on accleration after 5500 RPM. Does the factory ECU actually retard the performance so much as to get a bad miss and very rich conditions? Any help would be appreciated because I am not experienced enough with cars to figure this out without expert advice.
Now I assume you do realise that the water-pump is driven off the same pulley that the factory viscous/thermatic fan is mounted to, yes?
If this isn't being driven, you have no coolant flow. If it is being driven, is it slipping badly? That could cause the water in the block to have too low a pressure. Both these would cause high oil temps, too.
110deg C oil temps at idle are ridiculously high.
Part-time electric thermo fans are garbage for hi-po engines like RB26's, the engine bay should have a constant supply of fan driven air to keep heat-soak down. Plus the mechanical fan pulls air through the intercooler.
And finally- always use a radiator fan shrould. The radiator won't be as efficient without one.
Hope this helps.
Did you buy the car with the current radiator setup on it, or have recently swapped it and the overheating issue has started since the swap.
Does it overheat when driving on the freeway or at a reasonably constant speed?
If it doesn't cook when driving there are a couple of quick things to check,
1) that the fan has the blades around the right way to pull the air through the core (or push if you have it on the front)
2) That the factory thermo mounted to the front is still working (it should kick in at about 90 degrees).
I suspect that it is an airflow issue and the single 14 can't pull enough air through the core as it's a pretty thick unit
On a general maintenence front, it's worth checking that the thermostat isn't stuck shut if it overheats no matter what and also run a flush through the system to clean out any scale and shit from the block.
How quickly does this happen? I suspect the thermostat if it happens quickly.
A 14" fan will not pull enough air through even if it's working properly but on cool days driving along it should still be fine. I think some of them can be wired backwards which can spin the fan in the wrong direction.
Stock fan or 16" thermo, stock is better.
Thanks for the comments. My first thought was that the stock fan would be much better as it is about twice the size of this electric fan, which is definitely a piece of junk, the problem with the stock fan is that when the engine is reved the blades bend forward and smashed the crap out of the rad before. had to get a new one ordered in, however it was installed at a body shop and not by me. is there a stock sized fan that would not bend like this that I could mount on the water pump pulley?
I have one more question. Where is the connector for the outside temperature sensor located? The manual says to disconnect this sensor with ignition on to force the Auto A/C into heat mode but the picture in the book really sucks and I can't figure out where this connector is located.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
