Hi Guys,
I have lost my licence for 6 - 8 months so i dont see any point in having my car anymore. As we as i have decided to start a project car. Either 32GTST or GTR.
Modz are as followed.
Car is manual with 86,xxx on the clock. With the following mods it put out 174RWKW. (stock computer, stock turbo)
- 5 Puck, Brass Button Clutch.
- CAI with POD
- 3" from the turbo back
- High-Flowed Cat
- Geniune Nismo Steering Wheel and Gear Knob
- No Rear wing (makes it look fat, with the 265's)
- Tinting (not heeps dark...)
- Firenza 265/45/18 on the rear and 235/40/18 TOYO on the front. (95% on front, 80% on back)
- Dual Stage boost controller (6 - 12PSI)
- Custom front bar, dont know what brand (possibly R33 Mspec)
- Awsome stereo (not custom install though)
- Coilovers on all four corners
- Lowered
- Turbo Timer (Apexi)
- C's Short Shifter Kit
- Custom dash with EL Lights.
I am not in a huge hurry to have her gone, i will offer her for sale with everything and fully stock.
With everything - $15,495
Without Rims, (comes with stock 33 Rims) Dual Stage, Short Shifter, EL Lighting Stereo - $12,495
Stereo consists of:-
- Sony M8815X Headunit (cost me over $1200 about 12 months ago)
- 2 x Kicker (dont remember the model numbers) 400W x 2 channel amps.
- 1 x Kicker 380W splits with high powered tweeters. (front)
- 1 x Rockford Fostgate 500W Speakers (rear)
- 15" JBL 1400W Peak Subwoofer with box. (am not seling with sub amp.)
Any questions please post below, May be interested in a swap for a manual 32 + cash or Modifyed 32 GTST/GTS4.
Prices are FIRM!!!
-SiNDOWS
Images are huge:
- Image 1
- Image 2
- Image 3
- Image 4
- Image 5
- Image 6
- Image 7
- Image 8
Also do you have a coller ect?
What is this? :S
any other mods to the motor, is there any issues with oil use or turbo?
- No other mods to motor... Service was done about 3k ago, will be doing another soon/before the car goes to the new owner.
- No issues with turbo or oil use. Always serviced with best components. (Motul Turbolight, Platium Plugs)
ME NO SPEKA NO ENGLISH, LOL.
sorry mate i meant intercooler.
Oh ok,
I tryed to email you the pics... But the zipped file is 14MB and your mailbox rejected it...
Is there another email i can send it to...
FYI - KM's are original as i have the log books from japan!
i was jokeing in regards to english, i am a terible speller. LOL.
yeah well humm i think my hotmail one can accept files that big, send to
[email protected]
Sending now!
wanted to send you a PM but your PM's not working or full.
so here you go..
I am semi interested in an R33 but don't want to go through selling my car for it etc..
Let me know if you are interested in a straight swap (your car in a $12K price set up)
my car is a 4 door R32 GTS4
so it is 4wd and 4 doors.
mods are:
FMIC
boost controller
suspension
gtr wheels
panel filter in stock box.
Colour is R33 GTR purple.
see pics.
It's hard to find a MANUAL 4wd 4 door and it is easily worth more than $12K so I am only interested in a straight swap so I thought I'd run it by you to see if you'd be interested.
Let me know..
Thanks
so here you go..
mods are:
FMIC
boost controller
suspension
gtr wheels
Let me know..
Thanks
Im sorry im not interested... I am not a fan of the 4 door skylines.
If it was a GTS4 i would have jumped.
Will post some more pics today when i have finished working as i am flat out today i cant even whore!!!
I will give you a schlap over the face with a dead tuna fish... Get out of my thread....
your the one who posted it to me!
and resize your damm pic!
but seriously.. i will offer $2.15 for it :)
hay thanks mate, not a bad looking car, still unsure about the removal of the spoiler, looks like something is missing.
I'll keep your car inmind now that i know what it looks like
Yepo...
I still have the spoiler, everything which i have taken out of the car when modifying it will be supplied...
i.e. wing, airbox
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
