Here's a little snippet from the front page of the local paper.....
I'm a bit shocked that they only managed to issue 85 defect notices.
There were about 6 Police cars doing laps on Dandenong Rd between Corrigan and Spag Junction, so those numbers mean that they only handed out about 3 defect notices (per patrol car) each day.
Slackers.
https://www.sau.com.au/forums/topic/114713-easternats/
slack i say they are pricks for targeting easternats whole point of easternats is so dickheads get off the street, now thinck this, you go to nats so you cant get a ticket but when you leave and go outside bang copy one?? how would you feel. or even better you go to nats to wacht it with your car you leave and bang pulled over ticket assholesssssss.....
https://www.sau.com.au/forums/topic/114713-easternats/#findComment-2118481
if your car is unroadworthy and deemed illegal, then why are they assholes ???
please point me in the direction where it states that they defect cars that arent defectable?
they defect cars that are defectable, cause there is something wrong with them
i agree tho, some of the measures they go to get defects is utter b.s
but its the law none-the-less
so put up with it, shut up
or ride a push bike ...
u sound like a f*kn pom
https://www.sau.com.au/forums/topic/114713-easternats/#findComment-2118628
haha.. dunno if it's just my browser, but that image i attached says "lick to enlarge"
I don't recommend licking it :P
Same on mine too :devil:
If u were doing something stoopid i say good u deserve it, but to just pull people over for revenue bonus' is just unfair!!!
https://www.sau.com.au/forums/topic/114713-easternats/#findComment-2122155
I don't recommend licking it :devil:
wish u posted that in the original post... by the time i got to this one it was too late... :)
i should have cleaned the screen before i licked it.
EW!
:P
you have to expect that kind of thing from the police though these days and half of them by the sounds of it deserved it. I know when i go to events that im spectating i would always go in an inconspicuous car that doesnt attract attention :( although now i dont have much of a choice ;)
https://www.sau.com.au/forums/topic/114713-easternats/#findComment-2122484
AND YOU, MY FRIEND, SOUND LIKE A F*KN BIGOT
Also just on the defect issue....
1st "if your car is unroadworthy and deemed illegal, then why are they assholes ???"
then.. "some of the measures they go to get defects is utter b.s"
Make up your mind, either that or become proficient in pulling splinters out of your arse.
We all know of at least one person who has been defected for less than acceptable reasons. Maybe the cop was having a bad day, maybe their donuts were stale, or maybe their bribe wasn't enough. Regardless, any cops who defects a vehicle just because they feel like it/think it's the right thing to do, is an ARSEHOLE. PEROID!
Bloody poms, we're everywhere! :)
https://www.sau.com.au/forums/topic/114713-easternats/#findComment-2127872
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
