More than likely not
But in theory it should due to some of the air running back into the engine and not getting dumped into the atmosphere?
Ill play with this and get back. This whole "pshhht sick uleh" shit is bit annoying considering the car is not as reliable as its with a stock bov.
GFB hybrid was installed on my car for years, no issues with stalling from it, full atmo was swapped and i had that issue.. it will be better than a full atmo.
So no stalling at all on 50 50? Cos I been driving with it for a few days now and it stalled completely once when I was idling... and then also had these small "set backs" like when I pushed the throttle and it just stalled for half a sec then let go and was fine again... this really pisses me off.
Edited by Sir-D
no stalling at all related to the 50,50 setup i had.
each car is different though, they are worse than people sometimes lol
thanks dude... ill give it a go this week.
PS love the pod suction noise and flutter... did u lose any of that? how did she sound on 50 50?
i've got a stealthfx .. on about 60/40 cos i don't want it too loud .. i have no stalling issues whatsoever . .even if i put in the clutch and let the revs fall.
if you are getting stalling, adjust the spring tension by twisting the cap only. that will make the bov close sooner and should get rid of your stalling issues.
Was it the stealth fx BOV??
I so want that bov.. Best soundin one i have heard..
What does your sounds like on just plumback??
no its GFB Hybrid... u can have 50 atmo 50 plumback setting.
my mate has Stealth FX on his s15... it sounds the best like u said... the flutter down low and awesome water splash when giving it!
well the flutter on a skyline is compressor surge not such a good thing to have if you value the life of the turbo. the 50/50 set up should be fine.
yeah its the BOV fluttering and it says that its OK for flutter at low RPM in the booklet.
at high rpm it whistles!
also look at VL turbos... they have no bov... and their turbos seemed to last for years.
I still get a flutter (gfb hybrid on 50/50) noise on low boost but thats coming from the bov it self as piston slides up and down.
When i took the bov off it fluttered in a different way.
u just connect the hose to the plumback trumpet right and vent the atmo plug yeh?
one pointing towrds you and is round, put hose over that to the std plumb back piping..
the other is a trumpet and you leave it alone.
just have to swivel the bov on the adapter so its in the right position..
edit : use hose clamps
Edited by Craved
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
