Gday guys just want to start a little bit of a open discussion here, we all know that usually the more octane you run(obviously to a certain limit) the better it is for your car when your dragging/track etc but since you all know the petrol prices have sky rocketed, $1.41 at mobil just before for synergy so i just want to see what people think/experienced when running normal octane petrol not 98 RON? i have been running mobils synergy since i got my car like 2 years ago and it has never noticably misfired or had a problem due to a bad batch of petrol, but since im still at uni and earning jack shit a week was wondering what other people run? I dont go to the track and dont regularly drag so would it be worthwhile staying with 98RON?
https://www.sau.com.au/forums/topic/114916-petrol/
with the stock ecu if you put in crap fuel and nail it, it will pick up detonation and switch to the low octaine ING timing map and back off timing everywhere. it will certianly work, just feel a bit sucky and flatish.
users with aftermarket ecu's can achieve the same goal by basically taking say 5 degrees timing out the of IGN map and it should run medicoreish on crap fuel
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2115822
I'd rather put my sneakers on than resorting to not putting 98 RON petrol in my vehicle! Thats the last place to cut corners on a budget I say..
Edit - BTW I believe with the ignition retard, your fuel economy will suffer so you wont save much $$ at the end of the day. Maybe enough to pay for a cup of coffee and thats it.
Edited by Busky2k
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2116064
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
