Gday guys just want to start a little bit of a open discussion here, we all know that usually the more octane you run(obviously to a certain limit) the better it is for your car when your dragging/track etc but since you all know the petrol prices have sky rocketed, $1.41 at mobil just before for synergy so i just want to see what people think/experienced when running normal octane petrol not 98 RON? i have been running mobils synergy since i got my car like 2 years ago and it has never noticably misfired or had a problem due to a bad batch of petrol, but since im still at uni and earning jack shit a week was wondering what other people run? I dont go to the track and dont regularly drag so would it be worthwhile staying with 98RON?
https://www.sau.com.au/forums/topic/114916-petrol/
with the stock ecu if you put in crap fuel and nail it, it will pick up detonation and switch to the low octaine ING timing map and back off timing everywhere. it will certianly work, just feel a bit sucky and flatish.
users with aftermarket ecu's can achieve the same goal by basically taking say 5 degrees timing out the of IGN map and it should run medicoreish on crap fuel
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2115822
I'd rather put my sneakers on than resorting to not putting 98 RON petrol in my vehicle! Thats the last place to cut corners on a budget I say..
Edit - BTW I believe with the ignition retard, your fuel economy will suffer so you wont save much $$ at the end of the day. Maybe enough to pay for a cup of coffee and thats it.
Edited by Busky2k
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2116064
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
