I'll lend them to ya (32 GTR wheels)
Only if your prepared to outlay the purchase price of $1000
Being thats what im selling mine for as they are near perfect
Sorry if that sounds a bit rough, but your new to the forum, and not a club member.
So its a large risk (for anyone) to do so.
Refundable upon wheel return in condition i gave em to ya.
PM if interested
https://www.sau.com.au/forums/topic/115104-closed/#findComment-2119620
PM if interested
I've already become a member, how do I update my user profile to display my membership details?
Can we arrange a smaller outlay, say $500? I'm located in South Melbourne..
https://www.sau.com.au/forums/topic/115104-closed/#findComment-2119716
I have a set on my wife's R34 which is arriving in around 10 days. Its arriving in Sydney, but should be here in around 3 weeks. If you can wait that long, you can borrow them.
Pics can be seen here:
http://allblitz.com.au/cars/019_nskyline34gtxwhite.htm
Regards,
Husnu (Hus)
https://www.sau.com.au/forums/topic/115104-closed/#findComment-2119782
Regards,
Husnu (Hus)
Hi Husnu,
Thanks for the offer - but need rims ASAP!
The R34 looks great!
https://www.sau.com.au/forums/topic/115104-closed/#findComment-2119982
