Deal starting today 28\04\06 ending on the 20th\05\06
BEZELS
FOR ALL SKYLINES. R32 R33 R34 STAGER...And SIL & 180s
IF YOU GET A SET OF DIALS WE WILL CHUCK IN BEZELS FOR A MEAR $80(THATS THE FULL RING SET.)
IF SO MOVE TO THIS BUY:http://www.skylinesaustralia.com/forums/index.php?showtopic=113600
IF YOU WANT THEM WITH OUT GETTING DIALS THEY ARE $140 TO YOUR DOOR.
eg, r32 FULL SET OF BEZELS AND RING SET BRUSHED ALOY AND CHROME.
STAGER:
AND OTHERS. ie S13
PM ME FOR PAYMENT DETAILS :)
KEZZA
https://www.sau.com.au/forums/topic/115339-brushed-chrome-bezels/
  • Replies 125
easy as mate,The cluster comes out, then the clear plastic just unclips from the housing of the face plate, then just install the bezel set over the front of the dials. and clip the clear plastic back on, and your done :)
takes around 10 min tops, to change the whole look of the cluster :P
I got my self down for a set. WAY BETTER THAN PAINTING THE FACE PLATE!
kezza
hey, excuse the ignorance, but how do you get behind the plastic to change them? do you just take the cluster out and remove the backing?
ya its easy...I have doneit a few times wont take u more than 5min once the cluster is out.
KJ. btw thats a great price for this product...I paid double for the same FTO one.
yeah, Cyberstork has very good prices and terrific quality!, Thanks for the plug Khunjeng!
Ok,
DAN is in.
KAS is in.
Send me a pm dezz and you can be on the list mate :)
KJ is in also!!! $140 to the door!! nice1...I should have got the dials after all and not got them seperately!! next time :D
I'm sendint Kez a PM of confirmation in 5min once I have sent the funds (although they might not clear until monday)
KJ
The next thing u need is the needle caps...have a look at my FTO cluster below!! sorry about it being bright...
Edited by khunjeng
Which business is supplying this group buy Kezza
btw I have an R33 S1...I guess this is important!!! heheh KJ
No worries KJ R33 GTS-t S1 :worship:
Kezza mate, 2 thigns:
1. can you get the needle cap thingies? thye look really nice.
2. can you check to see whether the metal plate thingy is avaialble for sII r33? because the sII cluster is different and a sI one would look at bit weird.
Cheers mate
edit, saw theres no 33 pic available.
im interested in one for a s13 and a r33 series 1
thanks
james
wat about gtr?
Cheers mate
james: send me a PM of the bezels you need for year mod, and stuff, and ill give you my bank details and you can be on the list :P
KamikazeR33 Yes, what about GTR? Yes they are made for the GTRs as well bro! ie, pic up top of the R32 GTR.
I just dont have pics of all the bezels for all the cars. but they ARE made for them.
'97r33gtst-typeM' mate, i will double check your questions bro.. Im 99% sure they are made for the S2 R33...... The cap things are a good question, i will find out :)
kezza
interested if u can post a pic of an r33?
Hey Bill,
there is no pic available for the R33 right now, but its the same look as the other 3 pics available.
very very good looking, so I dont think you have to worry, :pwned:
is there something specific your checking for? I can double check for you if you need.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
