  • Replies 125
no they aren't...auto's have a different cluser because they have the gear indicator running between the gauges
Bezels and rings are available for both early and late model R32s and R33s as well as GTR, so that hopefully answers the question :P
Is this available for the R34GTT Auto cluster?
If so, I'm in!
I'll be in also if you can tell me for sure that the R33 Auto cluster is catered for, with the gear indicator inbetween the tacho and the speedo.
Just a question, the R34 dash is semi-3D - does this item cater for that or does it just make the entire unit flat again?
That's right, I'm just after the rings if available and if they still fit on the std facia.
Thanks.
satanic - yes its available for both the R34GTT Auto cluster and manual with the gear indicator being the difference. The bezel itself is flat, in either polished silver or chrome.
MacGuyver - YES, R33 Auto cluster is also catered for!
Wogboy - Rings alone cost $70, they will fit but its a much better value to buy in combo with the cluster and bezel combined.
Sorry for the delay in repling, mates!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
