ATP turbo is releasing T3 flanged split pulse or divided non gated turbine housings for the GT30R and GT3540R (GT3582R) range of turbos . No details yet on which AR ratios they intend to do but may be useful for some . They are also selling the .85AR T4 flanged divided Garrett housing for GT40R based turbos .
Cheers Adrian .
whats involved in getting the rb25 to run split pulse? is it as simple as manifold change? or is more comlpex such as changing firing sequence of each cylinder + suitable manifold?
very good info, thanks a
OEM manifolds for the RB sixes are all split pulse (to an extent) already. the flange will be the same, they will bolt on.
personally i would never build a manifold with an open collector, even if i was using an open collector turbo. split pulse all the way. the less pressure spiking you get transmitted to the other three cylinders the better IMHO.
ok right. so its just a case the standard turbocharger doesnt run split pulse.
so it should be as simple as bolting on a split pulse turbocharger and thats all u need to do. cool cool. i was under impression you would have to change the manifold and firing sequence to suit.
split pulse works in the sense say
cylinders 1,3,4 fire
into pulse zone 1
and cylinders 2,4,6 fire
into pulse zone 2
so the engine fires in order 1,2,3,4,5,6
and this results in gas flowing through each pulse zone in well "pulses" which keeps the exhaust wheel spinning at the best possible rate
or is the goal of split pulse to avoid collision (so to speak) in the manifold
ie: no two firing cylinders at the same meet up in the same pulse zone?
the firing sequence of the RB sixes is 1 5 3 6 2 4 IIRC - you will notice that each of the three cylinders linked by a common collector are separated by the firing of a cylinder NOT linked to it.
when your back pressure spikes due to an exhaust pulse, you don't want that pressure spike being "seen" by another cylinder just as the exhaust valve is open there too, it will hinder gas exit and increase the work of pumping. so you separate them as much as you can.
ideally then, six independent pulse housings would be ideal for your turbo, but it's just not practical. even better would be six individual tiny turbos, but that would simply not work.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
