Richard,
This is the part number for the OEM Nissan engine under tray. I am pretty sure it looks like this. i just ordered a new one from Nissan for $185, so 8000 yen is a very good deal
Yep, thats's the one :-)
Thanks for the quick reply Scott
Cheers,
Sean
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
