Heya guys!
Well I am doing a few mods again to the car and am wondering what limitations the standard Injectors, clutch, fuel pump and turbo have.
This could be a good knowledge base should some of you guys want to perform mods in future:cool:
I have heard that the clutch goes to about 250rwhp however i myself am making much more than that and is still holding ... JUST!! so i do agree with that statement as far as reliability goes now what about
turbo:
injectors:
fuel pump:
how many rwhp do you think they will last up to. also as discussed with members such as skyzer, rev210 and gtstvspec (THANKS GUYS:uh-huh: )instead of injectors a malpassi fuel regulator can be the way to go to get an extra 70 rwhp or so. i have heard ups and downs though about this. KILLERT did you have probs with your fuel regulator? anyone else?
https://www.sau.com.au/forums/topic/11579-r33-gtst-limitations/
well killer-t went the malpassi as its a cheaper option than replacing the injectors. hes up to about 300-315rwhp atm i think.
He was close to 100% duty cycle with the injectors at this stage teh malpassi has given him more room to play with the stock ones.
yes a number of hard launches and ur likely to fry your clutch at your current power.
Fuel pump may or maynot last i can't remember the specs on the stocker, u may want to replace just to be on the safe side.
turbo will most likely be at its limits now.
Guest KILLER-T
I think the the most power i got out of my stock turbo and fuel pump was 240 rwhp and it made that power for around 1 month then the fuel pump died i think it was workin real hard and the turbo was on its way out at this point to but i think that was my own fault running 14-15 psi in the middle of summer
(rwkw / 0.7455 = rwhp)
Im making 272rwhp and my clutch has just gone. (Although its a hard daily driver constantly on 7psi - 249rwhp). Even though i thought the clutch wasn't slipping and felt reeeeally smooth ive realised after having my new clutch installed today that it was deffinetly lacking performance.
Stock ECU
Stock Turbo
3" Full Exhaust
FMIC
HKS Pod
68,000km on the clock
thats it....
I'm sure my stock injectors and fuel pump are nearing the end of their lives but i have no easy way of telling.
Ben.
I had a Yellow R34 GTS max the fuel pump at 311 rwhp today
so we are fitting a SAFC and Bosch pump.
This thing was making this power at 16psi with a cooler
and Exhaust and a cheap un knowen turbo ($1500) and
was still climbing but we had to back of because the fuel pump.
Will let you now the final out come but 350hp looks possible.
Guest KILLER-T
Ok the limits of my injectors is 326.3 rwhp and there is not alot of head room left in them so i know whats on my shopping list.I just need to butter up my g/f first :P
So fitting a z32 afm and fuel reg gave me an extra 22 hp not a huge amount but just enough to notice a bit more pull in the car:burnout: :burnout:
Guest Peewee
haha so true steve but over here you see a lot of guys tunig to mid to high 12's but if tuned in summer come winter when the air is denser they WILL lean out! Killer t i reckon a big pump and malpassi you will be able to stretch 50 at least from your injectors but don't skimp on your pump
Originally posted by KILLER-T
Ok the limits of my injectors is 326.3 rwhp and there is not alot of head room left in them so i know whats on my shopping list.I just need to butter up my g/f first  :)
so the limit of your injectors of 326.3rwhp is that including the malpassi fuel regulator? Brett didn't seem to be a big fan of it the other day though????
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
