Hey all,
Short Story - my car was tuned recently, inectors are at 90%.....told you it was short.
Now, I am planning on getting Nismo 600cc injectors fitted but will this stop the ticking I am getting at the moment? Are mine currently ticking because they are at 90% load or is it because the lifters are dirty?
Its pissing me off yes
cheers.
https://www.sau.com.au/forums/topic/115826-ticking-injectors-lifters/
Hey all,
cheers.
Bloke - it is an RB26, with a mechnical (ie not hydraulic) valve train. It's the valve train. They all do it.
Be proud of what you have. :thumbsup:
Be proud of what you have. :O
MAKE IT STTTTTOPP! :bunny:
So bigger injectors still have no affect? and its not because its dirty/sticky?
tick tick tick tick !!BOOM!! ;)
Pump it up Prince :P
Its very embarissing driving a GTR that sounds like a diesel truck going passed 2500rpm :(. Driving passed train stations in the morning I try to keep the revs at idle, coz I know all the people are looking at me :P.
Maybe its it coz its a Skyline...
Yep, shes a whinging little bitch my engine, its fine at cold start but when the engine starts to heat up in the morning it ticks very loud. Then when I drive home its a lot quieter, almost silent.
Sorry to hijack the topic topaz,
I get a ticking noise in the morning or when the car is cold, the ticking increases with revs (mainly around the 2000rpm-3000rpm) after 3000rpm it cant be heard. Once the car has warmed up the noise dissapears. I was wondering if anyone can suggest a way of fixing it, it drives me nuts.
My car is a R33 GTS, i was wondering if it could be just the injectors or the lifters (or a broken lifter).
-cheers, michael
-cheers, michael
It sounds like your problem is more to do with lifter noise, specifically lack of lubrication at cold start.
This could be due to lack of oil, or more likely due to the fact the problem dissapears when the car is warm: Worn lifters or oil that is too (thick or thin) in its cold state.
What rating oil are you using and how many k's has your car done?
(BTW doesn't sound like a broken lifter, this would cause the noise all the time, probably alot louder as you rev).
car has done roughly 117000km
oil im not entirely sure about, got my mechanic to change it last time, i think its shell synthetic possibly 5W-40?? (it was changed about a month ago and still looks really clean
could you suggest an oil i should use
-michael
Lifter noise in FTO's is a common thing (most Mitsu's actually) and is often stopped by adjusting the lifters clearance, dunno if you can do this in the RB's but maybe look into it?
The type of oil you use also makes a difference.
Hey Micheal, sorry I didn't post back. I've been away on hols. Plus i'm trying not to hiijack this thread, but it looks like its too late for that so:
Now i'm not a mechanic so don't take this as gospel, but basically, skylines use hydralic lifters which as the name suggests, uses oil to fill the lifter.
When yoy stop your engine any one of your lifters on the camshaft lobe is under pressure of the valve spring; therefore a leak from the chamber can occur.
This is normal, and if you haven't driven your car for say 3-4 days and start it up, you'd expect to hear lifter noise for about 10 seconds or so as the fluid fills the lifters.
Now as a car gets older and the engine wears its normal for tollerances to become larger, that is why as your car gets older its a good idea to change the viscosity rating to suite the current condition of the engine.
Basically the older the engine the thicker the oil.
From the factory skyline ran a semi-syn at 7.5w, most guys on here (and it sounds like you too) Run a 5w fully syn, which is fine and probably better for the engines internals and turbo etc. But if you're really concerned about your cold weather starts on the lifters, you might want to consider running a slightly thicker oil, say 7 or 10w as this oil might take a fraction longer to reach the galleries, but fill them and operate a higher viscosity from start thus filling the lifters faster.
Beware though, because this might not fix your problem, there is always the chance you have problems with sludge build up, either in the oil pick up sleeve, or galleries. This can cause oil starvation until enough oil finally enters the lifters for them to work properly.
This is probably less likely though.
I'd get in my car and start it cold and keep an eye on the oil pressure gauge and see if it shoots up pretty much straight away. If it does you'r oil pressure should be good, and at least you know thats not really the problem, if it delays or stays low and takes a while to raise in pressure, this would suggest a worse problem then just clearance issues.
In the end, your mechanic should be able to advise you on the best cause of action for your car, obviously there could be other factors.
It might be an idea to leave your car with them overnight so they can to a true cold start and see how the car behaves.
Hope all this jibberish helps, and again as I said i'm not a mechanic.
Sorry to Topaz btw for hijacking this thread.
-Insu
I'm reasonably sure that the RB25's lifters are self adjusting.
Oh and BTW michael, i'm not sure if I mentioned it, but the downside to using to high a viscous oil on start up can be that the oil it harder to move and takes longer to fill the lifters, which can be worse. So don't go to thick.
Also, there are other things that can cause a ticking when the engine is cold such as a crack in the exhaust manifold that expands and closes once the car is warmed up etc...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
