I am happy with where ever, like i said im at wk till 5, happy to drive. I was looking on map as your in hillarys im in cannington how about we all meet in car park of Harvey Norman city west at 6pm? Its central i guess to us all, easy to get to and out of other drivers way? Just an idea but am open for other offers
Sounds like a plan - I'm cool with that - we can make it at 6 pm and that prob will give you more time to drive and ready ? Hopefully it's not to Dark to check out the cars ? Either am open for any options too - Sunday morning / Monday - when ever -
I'm a girl - don't know how to paint [emoji23][emoji23]
Not easy to mess around with R35 wheels [emoji24][emoji24][emoji24][emoji24]
What a shame you can't join us but yea hopefully next time -
Elle x
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
