I am happy with where ever, like i said im at wk till 5, happy to drive. I was looking on map as your in hillarys im in cannington how about we all meet in car park of Harvey Norman city west at 6pm? Its central i guess to us all, easy to get to and out of other drivers way? Just an idea but am open for other offers
Sounds like a plan - I'm cool with that - we can make it at 6 pm and that prob will give you more time to drive and ready ? Hopefully it's not to Dark to check out the cars ? Either am open for any options too - Sunday morning / Monday - when ever -
I'm a girl - don't know how to paint [emoji23][emoji23]
Not easy to mess around with R35 wheels [emoji24][emoji24][emoji24][emoji24]
What a shame you can't join us but yea hopefully next time -
Elle x
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
