BSK Posted May 2, 2006 Share Posted May 2, 2006 during a phone conversation today with a local tuning shop i was told i should be using a wastegate to run 1.2bar on my rb20 powered 32. i have had the car for 3 months now and it has been happy to run 1.2bar thru its gt2510 probably half the time i drive it... is it true i should use gate to run this boost? or is there a sales pitch going on?? im pretty sure 1.2bar is no sweat for this turbo but i though i'd get another opinion from u guys... Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/ Share on other sites More sharing options...
paulr33 Posted May 2, 2006 Share Posted May 2, 2006 its much better to run boost control via the wastegaste. if for example you have as 0.50bar wastergate and want to run 1.1bar boost then the controller has to work very hard to maintain the pressure difference, it will likely fail and try its best. that being said if you move to a 1 bar actuator thats the minimum about of boost you can run, ie you cant have a 1 bar actuator and set your boost controller to run 8psi Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134287 Share on other sites More sharing options...
R31Nismoid Posted May 2, 2006 Share Posted May 2, 2006 Off the gate is better. Reason being (at least with external) you get the spring rate that is closest to your target boost. This ensures you dont have wastegate creep/gate doesnt open prematurely etc. I ran 15psi straight off my gate and bleed it upto 17psi. When i had the 7psi spring, i would get gate creep in 5th gear as it was coming onto boost so it would take longer to build 17psi. And thus under a great load the car became much slower as it took forever to build boost in taller gears definately not a sales pitch cheers Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134305 Share on other sites More sharing options...
BSK Posted May 2, 2006 Author Share Posted May 2, 2006 sorry my bad..... i meant an external wastegate. Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134304 Share on other sites More sharing options...
paulr33 Posted May 2, 2006 Share Posted May 2, 2006 ash is spot on, sorry i thought u meant internal gate Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134310 Share on other sites More sharing options...
Craved Posted May 2, 2006 Share Posted May 2, 2006 2510 is internally gated, i wouldn't see why they would get you to run an external gate on that.. maybe upgrade the actuator, but not swap to external Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134334 Share on other sites More sharing options...
BSK Posted May 2, 2006 Author Share Posted May 2, 2006 2510 is internally gated, i wouldn't see why they would get you to run an external gate on that..maybe upgrade the actuator, but not swap to external funnily enough it has a nissan stamped actuator.... ? dont know if thats what comes on the gt2510 or an upgrade Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134355 Share on other sites More sharing options...
Craved Posted May 2, 2006 Share Posted May 2, 2006 well i doubt it would come with the 2510, could be the old rb20 one ..and not the one that came with the turbo from the shop .. hard to say Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134357 Share on other sites More sharing options...
R31Nismoid Posted May 2, 2006 Share Posted May 2, 2006 so its an int gated turbo? hardly worth converting it to ext gate, i think in THAT case you have been had Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134367 Share on other sites More sharing options...
Craved Posted May 2, 2006 Share Posted May 2, 2006 get an upgraded actuator for the reasons that R31nismoid and Paulr33 have said. Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2134372 Share on other sites More sharing options...
RB power Posted May 3, 2006 Share Posted May 3, 2006 Off the gate is better.Reason being (at least with external) you get the spring rate that is closest to your target boost. This ensures you dont have wastegate creep/gate doesnt open prematurely etc. I ran 15psi straight off my gate and bleed it upto 17psi. When i had the 7psi spring, i would get gate creep in 5th gear as it was coming onto boost so it would take longer to build 17psi. And thus under a great load the car became much slower as it took forever to build boost in taller gears definately not a sales pitch cheers hi so if im running a 9psi spring in my external and have a ebc set at 16psi will it thake longer to build boost than if i had a 14 psi spring and ebc set at 16? Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2136052 Share on other sites More sharing options...
BSK Posted May 3, 2006 Author Share Posted May 3, 2006 (edited) ok, so i still dont think i need another gate because theres is no gate creep or boost problems that i can notice so there is no problem in my mind but thanks heaps for the tips and info guys. soo...just for my own curiosity and maybe some future tinkering with... are upgraded internal gates a brand name aftermarket item? or oem/second hand items available off other turbos on the market? Edited May 3, 2006 by BSK Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2136192 Share on other sites More sharing options...
R31Nismoid Posted May 3, 2006 Share Posted May 3, 2006 Your turbo is internally gated yes? If so, there is no "shelf upgrade" The internal Wastegate is a part of the turbine housing of the turbo itself They can be modified (ie drilled out) and other things, but again, i dont think you need it cheers Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2136728 Share on other sites More sharing options...
R31Nismoid Posted May 3, 2006 Share Posted May 3, 2006 hi so if im running a 9psi spring in my external and have a ebc set at 16psi will it thake longer to build boost than if i had a 14 psi spring and ebc set at 16? potentially yes. every car is different, and you might not have a problem. But its always best to get it close as you can to give you gauranted max performance In lower gears you might not notice this. IMO you dont need an EBC on an external gate, i only ever used a bleed valve as you let the wastegate do the work for you. That is, after all its job... to control boost. Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2136731 Share on other sites More sharing options...
Craved Posted May 3, 2006 Share Posted May 3, 2006 the less work the boost controller has to do the better.. a more stable boost curve will be acheivable with a gate spring that is closer to desired boost level rather than relying on the boost controller to modify the pressure the gate is recieving. in the example with a 9psi spring, it will make it to 9psi fine but the progression after that can be affected with the delay and duty cycle of the boost controller. HKS sell adjustable actuators. could use other ones but not many cars run 14psi std .. so aftermarket is where you would have to go. Link to comment https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/#findComment-2136738 Share on other sites More sharing options...
