during a phone conversation today with a local tuning shop i was told i should be using a wastegate to run 1.2bar on my rb20 powered 32. i have had the car for 3 months now and it has been happy to run 1.2bar thru its gt2510 probably half the time i drive it...
is it true i should use gate to run this boost? or is there a sales pitch going on??
im pretty sure 1.2bar is no sweat for this turbo but i though i'd get another opinion from u guys...
https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/
its much better to run boost control via the wastegaste.
if for example you have as 0.50bar wastergate and want to run 1.1bar boost then the controller has to work very hard to maintain the pressure difference, it will likely fail and try its best.
that being said if you move to a 1 bar actuator thats the minimum about of boost you can run, ie you cant have a 1 bar actuator and set your boost controller to run 8psi
Off the gate is better.
Reason being (at least with external) you get the spring rate that is closest to your target boost.
This ensures you dont have wastegate creep/gate doesnt open prematurely etc.
I ran 15psi straight off my gate and bleed it upto 17psi.
When i had the 7psi spring, i would get gate creep in 5th gear as it was coming onto boost so it would take longer to build 17psi.
And thus under a great load the car became much slower as it took forever to build boost in taller gears
definately not a sales pitch
cheers
2510 is internally gated, i wouldn't see why they would get you to run an external gate on that..
maybe upgrade the actuator, but not swap to external
funnily enough it has a nissan stamped actuator.... ?
dont know if thats what comes on the gt2510 or an upgrade
cheers
hi so if im running a 9psi spring in my external and have a ebc set at 16psi will it thake longer to build boost than if i had a 14 psi spring and ebc set at 16?
ok, so i still dont think i need another gate because theres is no gate creep or boost problems that i can notice so there is no problem in my mind but thanks heaps for the tips and info guys.
soo...just for my own curiosity and maybe some future tinkering with...
are upgraded internal gates a brand name aftermarket item?
or
oem/second hand items available off other turbos on the market?
Edited by BSK
Your turbo is internally gated yes?
If so, there is no "shelf upgrade"
The internal Wastegate is a part of the turbine housing of the turbo itself
They can be modified (ie drilled out) and other things, but again, i dont think you need it
cheers
potentially yes. every car is different, and you might not have a problem.
But its always best to get it close as you can to give you gauranted max performance
In lower gears you might not notice this.
IMO you dont need an EBC on an external gate, i only ever used a bleed valve as you let the wastegate do the work for you.
That is, after all its job... to control boost.
the less work the boost controller has to do the better.. a more stable boost curve will be acheivable with a gate spring that is closer to desired boost level rather than relying on the boost controller to modify the pressure the gate is recieving.
in the example with a 9psi spring, it will make it to 9psi fine but the progression after that can be affected with the delay and duty cycle of the boost controller.
HKS sell adjustable actuators. could use other ones but not many cars run 14psi std .. so aftermarket is where you would have to go.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
