during a phone conversation today with a local tuning shop i was told i should be using a wastegate to run 1.2bar on my rb20 powered 32. i have had the car for 3 months now and it has been happy to run 1.2bar thru its gt2510 probably half the time i drive it...
is it true i should use gate to run this boost? or is there a sales pitch going on??
im pretty sure 1.2bar is no sweat for this turbo but i though i'd get another opinion from u guys...
https://www.sau.com.au/forums/topic/115969-wastegate-truth-or-lies/
its much better to run boost control via the wastegaste.
if for example you have as 0.50bar wastergate and want to run 1.1bar boost then the controller has to work very hard to maintain the pressure difference, it will likely fail and try its best.
that being said if you move to a 1 bar actuator thats the minimum about of boost you can run, ie you cant have a 1 bar actuator and set your boost controller to run 8psi
Off the gate is better.
Reason being (at least with external) you get the spring rate that is closest to your target boost.
This ensures you dont have wastegate creep/gate doesnt open prematurely etc.
I ran 15psi straight off my gate and bleed it upto 17psi.
When i had the 7psi spring, i would get gate creep in 5th gear as it was coming onto boost so it would take longer to build 17psi.
And thus under a great load the car became much slower as it took forever to build boost in taller gears
definately not a sales pitch
cheers
2510 is internally gated, i wouldn't see why they would get you to run an external gate on that..
maybe upgrade the actuator, but not swap to external
funnily enough it has a nissan stamped actuator.... ?
dont know if thats what comes on the gt2510 or an upgrade
cheers
hi so if im running a 9psi spring in my external and have a ebc set at 16psi will it thake longer to build boost than if i had a 14 psi spring and ebc set at 16?
ok, so i still dont think i need another gate because theres is no gate creep or boost problems that i can notice so there is no problem in my mind but thanks heaps for the tips and info guys.
soo...just for my own curiosity and maybe some future tinkering with...
are upgraded internal gates a brand name aftermarket item?
or
oem/second hand items available off other turbos on the market?
Edited by BSK
Your turbo is internally gated yes?
If so, there is no "shelf upgrade"
The internal Wastegate is a part of the turbine housing of the turbo itself
They can be modified (ie drilled out) and other things, but again, i dont think you need it
cheers
potentially yes. every car is different, and you might not have a problem.
But its always best to get it close as you can to give you gauranted max performance
In lower gears you might not notice this.
IMO you dont need an EBC on an external gate, i only ever used a bleed valve as you let the wastegate do the work for you.
That is, after all its job... to control boost.
the less work the boost controller has to do the better.. a more stable boost curve will be acheivable with a gate spring that is closer to desired boost level rather than relying on the boost controller to modify the pressure the gate is recieving.
in the example with a 9psi spring, it will make it to 9psi fine but the progression after that can be affected with the delay and duty cycle of the boost controller.
HKS sell adjustable actuators. could use other ones but not many cars run 14psi std .. so aftermarket is where you would have to go.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
