Server is now up with Correct password and the following Maps.
32 Player Map (with room for 64 players)
Strike at Karkand
Daqang Oilfields
Wake Island 2007
Please advise if you have any issues.
PB_SV_GUIDRelax 4 has been run on the server.
(Thanks for posting the command who ever that was)
I have to do some work, but I will jump in later, I have advised the clan what is going on, and they may or may not jump online as well.
Any Problems Either SMS me (Urgent Issues only), 0410 491 599, or Xfire me, and I will get to it ASAP.
If Punkbuster causes issues (I had a shitfight with it yesterday, let me know, and we will turn it off completly, will require restart of server)
  • Replies 146
Posted Images
I am having issues getting in.
I am using Xfire, it asks for a passwd, I type in the supplied passwd as per pm and it throws me out stating passwrd incorrect. :P
With regards to teamspeak, there really isn't any need with BF2 as it has its own built in team speak thingo does it not?
The password is sau
Teamspeak is better then BF2's VOIP 'cause it allows chatter not just inside each squad.
However, it is entirely up to you what protocol you want to use.
As for Closing time, no, as yet, I don't have an official closing time,
I will try and keep it open for as long as possible.
Estimate at least 8pm this evening, maybe longer)
Was a pretty dismal turn out.
Last time i do something like that.
But i will thank those people that came in as well as those who help made it happen!
dont loose heart man not ur fault it was organised the same day time as a cruise i think make it for 9pm again on another sunday and most of us could probably make it
as sum1 else posted they thought it was @ 9pm
Yeah, Sorry guys that I wasn't able to turn up.
Unfortunantly, my time of procrastination about household chores caught up with me, and I was forced to do them on Sunday.
Let me know the date for the next war, and as long as the Clan don't have plans for it, I am more then happy to allow you guys to utilise the BF2 Server again.
How was the server for everyone? Stable? any Issues? (We had issues the night before, So I just want to make sure everything went ok on the day)
Next time, We will start the server with 16 player maps, then upsize them as required...
(64 players on a 16 player map would be insane :thumbsup:, Let's see if we can pull it off :wave:)
Edited by Anthos
Once I reformat my machine so I can bloody get BF2 working again I'll definately be keen for a few games and will try and get some others I know to join in as well.
It's been a few months since I've played though. Apparently I can't jump and throw C4 anymore :D
Apparently I can't jump and throw C4 anymore :P
Thats right and if you havn't played it since about that time then they have made some other changes too.
PS if you wanna join the next one initially its looking to be not this weekend coming but the floowing sunday, which would make it Sunday 4th of June
Ok I have put my reminder on for Sunday the 4th of June at 9pm.
Is it the same server?
Sorry I couldn't make it either lads. Unfortunately I was out helping fix a mates car at that time. As previously suggested, a later slot would be better around 8 - 9pm.
Bit hard for alot of people to make it at lunchtime on a sunday, especially if they have been out on the turps the night before :sweat:
Will take some time before you get some good turnouts, hang in there
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
