Stupid question (and sorry to hijack :D) but where does one get wrap and flameproof paint from to paint over it (ala Beer Baron styles). Just got my dump pipe made and want to try and contain the heat somewhat.
Is it something that mopst places sell like Autobarn?
i got the wrap from Flyn (was cheap enough) and the paint from autobarn. i used the black paint. comes in a red can and says flameproof on it - up to 1500 degrees f. give it a few coats.
You can also buy it through Racespec on SAU. His prices are much better than R.R., but for the paint it probably doesn't matter much.
You can also get it from E.T. Performance in Dandy. They sell a couple of different widths and lengths, and pretty cheap too.
Also, be interesting to see how you go with that black paint...personally i will never use that rubbishg again. First can stopped workign after about 5 seconds leaving me with a uselass $50 can full of hi-temp silicon spray for exhaust wrap that i couldnt get out of the can
i believe i have some useful advice. with that can what sort of nib does it have? you should be able to replace it (im not sure what sort of can it is) so find a nib that is a similar size. put it on the can, turn it upside down and spray away. this will clean the tube that goes to the bottom of the can and spray just gas through it. (does that make sense?) every time it block up just turn it upside down and pump the nib (it should clean it if its still wet).
even a lynx can nib should do te trick. (if it fits)
forgive me if im wrong cos i assume its a can with a nib.
cheers. james.
Its not worth bothering with the flame proof paint. The moment you get your exhaust really up to temperature when on boost it will fry off instantly.
I actually had problems with my other car and melting the white header wrap. It first started to go brittle, and then started falling apart. Closer inpsection revealed that the glass wrap had melted and I had glass beads in the pattern of the header wrap stuck to my stainless manifold.
I've since changed to graphite impregnated wrap from horsepowerinabox and that sorted out the melting issue. Here's a pic of my setup.
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
