Im searching for the following parts for our 96 RS4:
-front bar - found
-front lip spoiler - found
-radiator support assembly - still needed
-front subframe tie bar (R33 GTR?) - still needed
-left rear upper control arm (R33 GTST - non HICAS model?) - found
-left rear toe control arm (R33 GTST - non HICAS model?) - still needed
-left front gaurd - found
-front headlights - found
-front driving lights - found
-front indicators - found
-front bar reinforcement - still needed
Anyone have any of these parts laying around?
https://www.sau.com.au/forums/topic/116279-stagea-parts-needed-asap/
-left rear upper control arm (R33 GTST - non HICAS model?) - still needed
-left front gaurd - still needed
ANYONE?
I may be able to supply the rear suspension parts if my mate picks up a GTST at auction tomorrow which we will strip.
I may also be able to provide a slightly damaged front passenger fender if the company thats going to fix my car replaces it.
Thanks Alex, your a champ. I received the lights today aswell - thanks again :P
Ive already got the upper and lower control arm and a toe control arm from a GTST.
The lower control is the same but the upper control arm and toe control arm appears to be different.
Wondering if you might be able to clarify this for me at all?
SK told me that I may require a toe control arm from a non-hicas GTST? :D
I may also have the front gaurd lined up already - will let you know. :laugh:
mate if it was the upper control arm i could have helped you, i just had mine replaced with adjustables.
No probs mate. thnx anyway.
I didnt have any troubles with the upper and 2 lower arms, as they are the same as the R33 GTST.
Having trouble finding the toe arm though. Not sure if it is the same as any skylines either??? no one seems to know... :D
Thought about going through Nissan but the dealers are useless where I live.
They didnt even know skylines existed after 88!!
:D
Having trouble finding the toe arm though. Not sure if it is the same as any skylines either??? no one seems to know... :ermm:
:D
hope this helps
Toe Control Arms
hope this helps
Toe Control Arms
Thanks for that. Ive contacted them and am now awaiting a reply.
I also found them through Gold coast Nissan.
Brand new nissan part (1 only) - $245 :D
This will be my last resort...
Just a thought, radiator support same as R34? only because headlights bolt in after they convert the front ends.
No there not
I will be removing at least the top panel, if not the whole radiator support panel when I do the conversion and fitting a R34 panel
No there not
Yours is a series 2 isnt it? Is it the same as the series 1?
How long before you'll have thje rad support out?
I would think the S1 and S2 would be different, as the head lights are, so the mounting points will not line up
At this stage, I am not sure if I can just change the top part of the support. The masa kit photo only shows the top bit which is only approx $120-130? from nissan for a R34.
Have you tried nissan for a price?
Get on to Alex for some part numbers, that way you will know for sure
Metro Nissan in Brisbane are pretty good for import parts, or you could order direct from www.japanparts.com
It will be at least 2 months before I get to mine.
No probs. Thanks for the info. ;)
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
