yeah i posted this in a thread a month ago but its allways good to see it again :P
the thread also wasnt based on the car it was R32 video i found :D then posted links to mines videos too i will dredge them up
http://www.skylinesaustralia.com/forums/in...howtopic=107808
post #10 and 11
Edited by Madaz
Regarding the V35 GT-R, it's interesting to see Cosworth are helping with engine, and Lotus with susp. Kinda sad really, shows they obviously lost some talented engineers during the troubled late 90's / early 00's.
And the questions over 4WD too, i understand why it may not be strictly necessary, but is it GT-R if RWD?
the 4wd system weighs alot (biggest hurdle) and if a car is balanced properly in terms of power and weight and chassis its better off being fr layout to b a competitive and renowned sporst car.
fr layout= no gtr :rofl: but they can adapt a 4wd systme to weigh close to nothing as they have done in a nissan hatchback(cant think of name in japan car market recently)
id like to see it represent japan and be unique rather than to try and compete on a new level to try and sustain gtr emblem. :angry:
I liked the idea of front electric motors, given that GT-R's have always been rear biased anyways, so the 'lectrics can kick in when needed.
That'd save weight in transfer cases and shafts etc but you'd probably more than gain it back in the motors and batteries.
*sigh*
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
