can someone help me out here i have a r32 with minor mods, but the weird thing is that the turbo doesnt start to spool until 3 to 3.5 grand and hits full boost at around 5grand, wat does this mean is it not standard turbo or is it fu%^ed.
any help will be appreciated.
Joel.
This will sound weird but my r33 was doing the same thing and it turned out to be my fuel pump so i put a walbro in tank one in and it is fine now. Im not sure why the boost was coming on late all i no is that the new pump fixed the problem.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145853
"""has the car been feeling sluggish? is it noisier at all when under boost?
you may have a slight leak in an intercooler/inlet pipe? checked all the clamps?""" (Azzurra)
no not slugish at all. it does seem to sound a little noisy i'll check the clamps...
well it has an aftermarket fuel pump an gtr injectors, an a malpassi fuel pressure regulator, but iv also noticed it only does it sometimes. Also Is there anyway to tell it the turbo has been high flowed-(rebuilt) without removing the turbo its self.
cause iv tested it on 12psi boost with out a FMIC an it runs perfect, iv been told not to run more then 10psi without a FMIC. i dont kno wats been done to it personally. also has a high flow cat an 3" system.
Edited by HR32_GTS-T
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145964
just sitting idling for a while, give it a bit, an then give it a bit later an it hits full boost at 3grand instead of around 5grand, weird i kno, but everything runs sweet an she go's hard, wat about the boost controller, i have no idea wat brand it is either, but it looks shitty.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145998
mate my car has the same problem i hit boost at 3000rpm but dont hit full boost till i hit 4500rpm i have a rb25det neo with an r33 turbo on it i wood like to no y it is doing this as it only just started playing up
i will go and c my mechanic tomoro after work and ask him i will let u no how i go.
ps if any one on here can help me plz let me no thanks
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146474
Check to make sure the wastegate actuator is not staying open. If it sticks or is getting stuck on something then it will be bypassing the exhaust gasses around the turbine. The easiest way to test this device is with a radiator pressure tester. Use it to pump pressure into the housing and confirm that the pressure it opens at is equal to the factory specs. If check is ok remove the mounting point where the actuator connects to the wastegate arm. There should be a small circlip. Use a pick or small screwdriver to remove it but be careful not to lose it. Check to make sure the arm moves freely and can open and close fully without interuption.
Check to see how easily the arm moves back and forth in the diaphragm. It should be difficult to move.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146807
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
