Hey all,
Im interested in buying a Skyline specifically a Gtr R33 and preferably a Rb25det or Rb26Dett Engine Under the hood. Ill be straight up honest i dont have a huge budget for it. Due to my budget im not really... Desperate to get a already moded out car, to be honest id rather do it myself but if there are good offeres with a car with some modding then id be more then happy to check it out. But please all leave offers and i will definatelly contact any who spark my interest or whome will negotiate a price i see visable.
My location is Brisbane, Queensland. So id prefer the seller to be somewhere around the general area, so i could come check the car out.
Thankyou all.
Dan
Please feel free to also or otherwise email me on [email protected]. Please include pictures in your post here or email aswell as spec's ... any modifications the engine etc, it would be much appreciated, and ofcourse the price your wanting / offering.
https://www.sau.com.au/forums/topic/116754-wtb-skyline-gtr-r33/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
