ok im running two amps, one for each sub how do i connect them both to the rca outlet on the backof the headunit... through the pass through outlets on one amp to the other... or with a y adapter to each one thanks in advance
Hey there,
You can do it both ways as you stated in your post.
If you have output RCA's from your amp then just use those, but its just as easy to get some splitters. The signal will be exactly the same.
Fixxxer :D
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2147922
I beleive it would halve it, yes, that's what I meant. It gives more chance of noise to be introduced, but since the split will be fairly near the end, it might not cause any issues. Cheaper and better to use the 1st amp's passthrough for the 2nd amp.
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2155989
Yeah if the passthrough is there use it. It's easily the best option.
In my car i had to use a splitter for the sub output because i accidently stuffed up one of the rca outputs by running 12v through it and for some reason i hear a thumping everytime i turn car on/off or change tracks or radio stations. Very annoying.
Well when i split it, the amp needed to be turned up alot more, but it could handle it. A cheap splitter is around $1 from jaycar so not very expensive.
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2156868
haha, splitters don't halve the signal :laughing-smiley-014:
Amplifiers draw something like microamps from the signal line, its nothing that could cause any signal loss. Your main worry should be noise when running the cable. Longer cables pick up more noise and you lose a little signal to resistance. Never run RCA's next to the power cable aswell, they produce alot of noise and grounding problems.
Turn on thump is most likely a grounding issue btw
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2159765
my head unit has done that since new... ive had it in for repair and they reakoned there was nothing wrong with it... (pioneer DEHP736) all i did to stop it was put a rocker switch on the remote wire... i turned it on and off before i turned the car off and after i switched it on or change radio stations ect... its a good thing to have if some nice policeman hears you music you can flick a switch and turn just the subs off until he passes :rofl:
on the rca note thanks all for your help i will definately be using the passthrough
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2161272
Yeah it's not actually signal lose your right but it is half the power. So the waveform going in is actually half the size of the non split one.
Thats not right :
Think about it like two resistors in parallel. Each resistor represents the input impedance of an amplifier (typically >10k ohms). One side of the resistor is grounded, the other is the RCA connection. If we ignore the slight resistance of the cable between the two amplifiers (its less than 1 ohm anyway) the resistors receive the exact same voltage. Current is split between the two... but thats irrelevant as amplifiers amplify the voltage at the input and not the current.
Signal loss can only really occur because the impedance has dropped at the amplifer side of the cable. So we have a 10k ohm impedance for one amp and a 5k ohm impedance for two (parallel resistors again). More current has to flow but accross a cable of say 50 ohms (exagerated) you only lose 0.1 of a volt for a 10v signal as opposed to 0.05 voltage for one amplifier.
In short, if your losing signal to RCA cables its probably a faulty cable or connector thats somehow making the resistance of the cable higher. Things like loose connectors, kinks in the cable, rubbing against metal and internal break from stretching will all cause it.
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2162592
While this is a very technical discussion, and I do have to agree that using splitters is not ideal, I think we have all over looked one small factor.
IT WONT MATTER. Yep, that's right. It wont matter one little bit.
The quality of equipment needed and its associated price makes this argument pointless.
Let me put it this way, go to a retailer, buy $1500- $2000 of equipment, instal rca splitters in the system and the equipment will not be of good enough quality to produce a level of sound quality that would represent an audible difference to the end user.
In English - the gear would not be good enough to hear the difference
On the other hand, spend $25k - $30k and you are starting to get into equipment that would be good enough to provide an oppurtunity to hear the difference.
And as logic would have it, if you were to spend that amount of money you would be getting equipment that would not need splitters anyway.
I guess at this point I should also provide an alternative, if you must use rca splitters and think they will effect your "sound quality" ( you wont hear it anyway) go out and waste, er spend you money on some crystal line drivers. They will take all the noise away.
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2163191
Thats not right :
I stand corrected. I was thinking about the current which doesn't really matter in this case.
Funny that because i did a whole yearly subject on op-amps and did soooo many equations with them and actually designed one at uni. Well thats what happens when you don't look over things for a year.
Thankyou for correcting me :)
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2163715
Thankyou for correcting me :D
No problems :)
frx026, I see the point your trying to make but splitters are actually the better option compared to pass throughs and line drivers. The signal remains shielded the entire time and isn't run through any components with noise of there own (e.g opamps) in a splitter. If it goes into an amplifier unsheilded (onto the board) with a switch mode power supply nearby and goes through an opamp and out again its going to pick up alot more noise than with a simple splitter.
That said, even if you spent 25k on audio gear I dout you'd hear the difference between a passthrough and splitter anyway. Its a limitation of our ears if anything.
As long as you don't buy absolute shit cable, you'll never have a problem. Any car audio salesman that tries to sell you oxygen free, quadruple shielded, snake-oil-included RCA's is just plain full of crap.
https://www.sau.com.au/forums/topic/116786-rca-question/#findComment-2164666
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
