  • Replies 513
Posted Images
I thought in an earlier post someone said that the pit lane garages will have power?
Stan, there are the "pit garages" which are actually on the pit lane and the ones being referred to as the "pits" which are free and just behind the pit lane garages, to sort out power etc for your crew, 48222811 - i think the person to speak to is Judy, but anyone on that line will help you out
4 common mistakes/bad habits for track driving compared to road driving.
#1 by far....over confidence/hero effect....unless you are pete you will end up in a paddock or wall. Just concentrate and build up speed and confidence slowly.
And the others....
#2 not braking hard enough - this is very common...you should be braking as hard as you can without locking the brakes up. Very easy to learn in a car with ABS since you just learn where ABS kicks in and then back off a little. WIthout ABS you need to practice carefully since if you brake too hard you will lock one or more tyres and the braking suddenly gets apalling when tyre is locked. But you will be amazed how hard a car can brake without locking up.
#3 not using the whole track - very common since we are all taught to drive on the left, how often do you get near the right hand gutter of the road? on a track you should use every inch, esepcially in getting to the apex in right hand turns (hard habit to break)
#4 turning in too early - this one is the hardest to get the hang of or even to notice you are doing. Generally, if you are getting a lot of oversteer OR understeer on exit it is probably because you turned in too early. especially in a powerful RWD with low grip (yep thats us, even GTRs) you need to turn in late, straight to the apex and on the gas in a straight line. If you turn in too early and get on the gas too early you will understeer on exit (fall off the outside) if the rears grip, or otherwise you will spin off the inside of the track (oversteer) if the rears let go.
Track driving is brilliant fun, but if you want to go faster you need to concentrate and practice. You should brake and turn in at the same spot each lap, judge it from a braking marker, line across the track etc etc etc, the best drivers brake and turn in within a metre every lap.
Thats some good advice Duncan, thanks!!
I can personally testament to #2 - I realised towards the end of the last track day that I wasnt even close to hitting ABS when I was braking! You would be amazed what warm/hot tyres and a usually smooth braking surface can do for your stopping power! It's tonnes more effective than cold tyres and an uneven braking surface (ie. what you would normally experience on the road.)
should be a great day people..nice cold weather can only mean 1 thing...POWER!! :D
ENTRY FORM HERE
Make sure you read the entry form thoroughly and if you are not sure ASK!
The above form MUST be filled out for your entry to be confirmed!!
Edited by RXB05S
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
