hey,
im just after some information on the r31 gts-r stock manifold.
Im looking at using one of my r33 rb25det, but im not 100% sure if the turbo will sit in the stock postion... can anyone confirmed if it will or wont?
and if anyone has any photos of it on an engine showing how the turbo sits please post them up
thankyou michael :O
https://www.sau.com.au/forums/topic/117121-gts-r-manifold/
The one thing i know far FAR too much about :O
You can fit anything upto a Garrett .7 A/R turbo on the front, with a .82 A/R on the rear, internally gated.
If you want External gate, its a mission if you want to keep it all hidden.
Thats as big as you can go without touching the engine mounts.
Although, i wouldnt bother using one on the stock turbo.
And i'd be interested to know where your getting it from as they (new) are i think $2000+ replica from Japan.
I wouldnt have sold mine for any less than $2k for a sale.
High price it seems, but when they are a limited edition off a limited motor/car setup.
They fetch nice high prices. So if your getting an original cheap then thats interesting
I know where my old one is if i ever needed it back :)
Hope that helps.
cheers.
https://www.sau.com.au/forums/topic/117121-gts-r-manifold/#findComment-2153025
thanks R31Nismoid, havnt bought one yet.. just saw one for sale..
my turbo is a hks gt2835 pro s, i just wanna make sure before i go ahead and buy it that my turbo will sit in the same postion it does with the stock manifold as i have a kit to suit that postion...
https://www.sau.com.au/forums/topic/117121-gts-r-manifold/#findComment-2153026
