can i buy it off you?
Sorry, i would like to keep it, if i put a 180km/hr dash in my speedo would probably be out by a looong way (i think)
Someonestole, is there any possibility that you could keep your Ceff, you've put the price down so much :woot:
Do we know which countries released the Cefiro as an actual local model (not a low volume import). As these cars probably would have had different speedos as they would have come out of the nissan factory as exports as opposed to a local release (like most of ours are).
New Zealand
