All,
I recieved a phone call from a wholesale friend I use for tyres. He has the following size Toyo R888's NEW available.
195x55x15's $165 each Low stock
215x50x15's $165 each
225x45x16's $200 each
215x45x17's $240 each 4 left
225x45x17's $250 each low stock
235x45x17's $250 each Sold out
255x40x17's $260 each Sold out
Sorry no 18's :thumbsup:
You will have to move quick as he is selling them to all his tyre shops at this price, post up and PM me if you are interested and can pay straight away. These are one of the best Semi's around, road leagal and great for track or drag work. Do your reseach on the internet before you buy.
Thanks Paul
great price...everyone thinking about doing some of the upcoming track days buy these :D They are about half the price of most semi slicks, and will be cheaper than wrecking road tyres at the track
What 15"'s are available....doing Wakefield or Oran soon so need some!
Please PM me some pricing for 15's and sizes available. Can see they come in 215, 205 & 195.....
or post..which ever is easiest!! Obviously lookin for 4 tyres....
Very Interested!!!!! Thanks Paul!!!
Ando
sorry if a dumb question.. but since theyre street legal how dou rate semi slicks in the rain and also as a street tyre in general (spirited driving)?... im very interested depending on that! id probaly be using them most of the time on the street and will see the occassional track day?... would it be better to get a specific road tyre or would these do??
OH and can u pay credit card :unsure:
To answer your question, very slippery would be the best way to describe the wet performance. These are a purpose built track tyre and do not really suit a daily road driver. You would only expect to get say 5000km tops on the road. Having uses the Toyo T1R, I can tell you it’s a better road/track tyre and is great in the wet. I got about 17,000km out of them with 5-6 track days. But the T1R's can be more expensive then the R888 prices above, but will last 3 times longer, but R888 will give you probably 3 sec quicker times at the track.
Wow they are top prices!
Yea agreed.. I need another set of rims!
Dont be tight and go buy some cheapo 15"s and chuck some semi slicks on em!!!! Im getting some 17's for daily use and the current 15' SSR rims will be track set, with semi slicks.....hopefully
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
