Hey all!
I know this topic has come up before, and I have read them all, but I just need to clarify how would you know
if the ATTESSA-ETS system is working at optimal performance when you buy an R32 GTR?
What would be the signs of a healthy ATTESA-ETS system?
What would be the bad signs of a ATTESA-ETS system that is not working properly?
Cheers guys!
https://www.sau.com.au/forums/topic/117257-r32-gtr-attesa-ets-testing/
Well its easy to tell if the system is all OK, if not the ATTESA light will be on on the dash.
However its much harder to tell if it is really healthy, because even if the system is working fine the centre clutch packs do wear, the system will think it is giving front torque but the actual torque transmitted might be minimal.
If you get the car dynoed in 2WD, leave the dyno unlocked and re-install the fuse and try and drive off the dyno.
If the clutch packs are in good nick, the car will drive straight off. If they are worn or slipping, it will move off more slowly (or not at all).
A subjective test I know, but if the dyno operator sees a lot of GT-Rs, he'll have a pretty good idea.
That's good advice: I'll give it a try!
What wbout the torque gauge? If the needle is slow to pick up when you give it a bit, couldn't that be a sign of an unhealthy attesa system?
I heard a healthy system, snaps the needle quite fast to full front torque load under max rear slippage.
What are your views on bleeding the attesa-ets system? I have heard that corrects many of the problems associated with no or low torque conversion to the front.
How do you know when your clutch packs are wrecked?
All opinions welcome!
Edited by skylimit
Well if the torque gauge is moving slowly that suggests that it is not bleeding or the clutch packs....the gauge reflects what the system is trying to do.
Maybe your longitudinal accelerometer is failing? I've not come across that problem but it must be possible/
The torque gauge actually has nothing to do with the mechanical side of the system. A completely stuffed transfer case will not be indicated by a lazy gauge, as the gauge signal is derived from an electrical output of the ATTESSA ECU it will still work, and should not be relied on.
We use a 80psi pressure gauge on the hydraulic line feeding the transfer case to make sure at least 50psi to 70psi (will vary depending on load) is present when front drive is operated. If this is ok then the transfer case is the problem (clutches worn or hydraulic actuator failure).
Hope this helps. :laugh:
Hope this helps. :)
hey paul do u happen to have a pic of how u plumb in a pressure line off the main hydraulic line??? sounds like a damn good idea and worthwhile as i dont even have a torque split gauge in mine (stagea).
its a simple matter of installing a "T" fitting at the rear of the box where line attaches or getting Pirtek or any other reputable hose doctor to install one in the line and cap it off when not in use.
paul is 100 % correct and its the only real way to test it properly.
hey paul cheers for that, so a regular oil pressure guage will be fine with a 0-100psi readout or does the pressure go higher than 100psi?
also on the r32 system vs the later model ones that hold the pressure..
does that mean the r32 gtr would read 0 psi when not operating 4wd and r33 and 34's would still have how much pressure when in 2wd?
Edited by CruiseLiner
Yes a 0-100psi gauge will do the trick. As for holding pressure on the later models....its the preload on the clutch plates in the transfer case not the pressure applied to the ATTESSA hydraulic actuator (rear of transfer case) that is the problem on newer models (this is why you cannot dyno R33 + R34 models in 2 whell mode without removing driveshaft). You should have 0psi pressure when in 2wd mode.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
