'cause it's got to be the worst possible place to put a battery. not only do you lose valuable space in the already small boot, but you get a significant voltage loss through the cable that runs from one end of the car to the other, meaning that any problems with the charge in the battery is magnifyed.
Define significant? Has it been a problem for you?
I'd suggest trying to isolate what's wrong before you do that. If it's your battery- get a new one. Otherwise, you could simply upgrade the factory wiring to better quality cable, incl the grounding points too.
That being said, I don't know anyone who's moved their battery from the boot :P
The current location also makes it a lot easier for stereo installs, no need to run cables all the way to the back if the battery is already there.
You clearly have something wrong with your electrical system. Fix that rather than attmepting a bandaid, which probably won't fix it anyway.
If you have a look at the cable, it is a big mofo. Voltage drop is very minimal.
You say that boot is already small. What, do you plan on putting something up on the top battery shelf? hmmm, like maybe a pad of paper? or a book? maybe a pair of undies? coz you won't fit much up there
it has been a little bit of a problem for me. if i dont' drive a lot for a couple of weeks, the car does have a bit of trouble starting , but my battery is only about 18 months old and still holds a good charge so that's not my problem.
It is a basic rule of electronics that the longer and thicker the cable/wire coming from a battery, the higher resistance there is,and the higher the resistance, the more voltage is lost through that cable. And obviously the more voltage you lose, the less effective the starter motor will be to crank the engine into life. So instead of you being able to lose say 2 Volts of charge from your battery and still being able to start the car, with the battery so far away you may only be able to lose 1 Volt of charge. Obviously, the more you have hanging off the battery, the more drain you'll get. It's not a huge problem for me, but it does say something that 99% of cars have the battery under the bonnet within a meter of the starter.
Obviously it's not sounding like anyone considers this mod worthwhile
if its still the standard size batt, then id change it to a slightly larger one, which most cars have. cause it is a small battery.
ive left my car for over 2 weeks before and it had no problems at all starting up. so i think you might have a wireing problem there that would need looking at.
Just get a bigger battery, the original battery is to small. Even if you put it in the engine bay you will have the same problem
I measured the drop in voltage from the alternator and also at the back. I also did it when the car was off. The voltage drop was negligible. We're talking like 0.2V.
you obviously have an electrical problem like I said above. moving the batt won't fix it.
Could be a dead batt - just coz it's 18 months old doens't mean it's still good. might be too small.
could be bad ground - clean them and make sure they're tight.
could be dead alternator.
I've left my car for 1 month and it still started.
Thicker cable = less resistance . Thats the reason they use a thick cable .
sorry guys. i got my wires crossed (pun completely intended). thicker cable does = less resistance.
what kind of batteries do others use and where did u get them? regular sales points like beaurepairs and the like don't seem to know much about the skyline's battery. One guy put a regular lead acid battery in it instead of the sealed lead acid type and the thing leaked all in my boot!!! thankfully i fixed that really quick.
Edited by vannic
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
