'cause it's got to be the worst possible place to put a battery. not only do you lose valuable space in the already small boot, but you get a significant voltage loss through the cable that runs from one end of the car to the other, meaning that any problems with the charge in the battery is magnifyed.
Define significant? Has it been a problem for you?
I'd suggest trying to isolate what's wrong before you do that. If it's your battery- get a new one. Otherwise, you could simply upgrade the factory wiring to better quality cable, incl the grounding points too.
That being said, I don't know anyone who's moved their battery from the boot :P
The current location also makes it a lot easier for stereo installs, no need to run cables all the way to the back if the battery is already there.
You clearly have something wrong with your electrical system. Fix that rather than attmepting a bandaid, which probably won't fix it anyway.
If you have a look at the cable, it is a big mofo. Voltage drop is very minimal.
You say that boot is already small. What, do you plan on putting something up on the top battery shelf? hmmm, like maybe a pad of paper? or a book? maybe a pair of undies? coz you won't fit much up there
it has been a little bit of a problem for me. if i dont' drive a lot for a couple of weeks, the car does have a bit of trouble starting , but my battery is only about 18 months old and still holds a good charge so that's not my problem.
It is a basic rule of electronics that the longer and thicker the cable/wire coming from a battery, the higher resistance there is,and the higher the resistance, the more voltage is lost through that cable. And obviously the more voltage you lose, the less effective the starter motor will be to crank the engine into life. So instead of you being able to lose say 2 Volts of charge from your battery and still being able to start the car, with the battery so far away you may only be able to lose 1 Volt of charge. Obviously, the more you have hanging off the battery, the more drain you'll get. It's not a huge problem for me, but it does say something that 99% of cars have the battery under the bonnet within a meter of the starter.
Obviously it's not sounding like anyone considers this mod worthwhile
if its still the standard size batt, then id change it to a slightly larger one, which most cars have. cause it is a small battery.
ive left my car for over 2 weeks before and it had no problems at all starting up. so i think you might have a wireing problem there that would need looking at.
Just get a bigger battery, the original battery is to small. Even if you put it in the engine bay you will have the same problem
I measured the drop in voltage from the alternator and also at the back. I also did it when the car was off. The voltage drop was negligible. We're talking like 0.2V.
you obviously have an electrical problem like I said above. moving the batt won't fix it.
Could be a dead batt - just coz it's 18 months old doens't mean it's still good. might be too small.
could be bad ground - clean them and make sure they're tight.
could be dead alternator.
I've left my car for 1 month and it still started.
Thicker cable = less resistance . Thats the reason they use a thick cable .
sorry guys. i got my wires crossed (pun completely intended). thicker cable does = less resistance.
what kind of batteries do others use and where did u get them? regular sales points like beaurepairs and the like don't seem to know much about the skyline's battery. One guy put a regular lead acid battery in it instead of the sealed lead acid type and the thing leaked all in my boot!!! thankfully i fixed that really quick.
Edited by vannic
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
