id be happy get over the chicks :D but ill leave the gettin under guys to u grls :P
no point arguing this. i cant c how u could disprove the theory, it stands up in every aspect. pretty solid for a guy i assume has had no experience with the ladies :burnout:
https://www.sau.com.au/forums/topic/11759-ladder-theory/#findComment-206049
Originally posted by MIZ.33T
why can't every1 GET OVER all this boy/girl thing and we all just foooken drive our cars....
the world would be much more happier.
Boys have a penis, and girls have a vagina.
https://www.sau.com.au/forums/topic/11759-ladder-theory/#findComment-206122
i cannot believe that Some1 actually took the time to write such a thing as it is just as bad as we actually wasting our time reading it...
Yes, some points raised are very 'true' indeed..... but one should realised that there are such things in life that DOES go beyond s3x, money and appearances...
one who is Oblivious to such thought would not progress very far with friends, life and relationships.... or would able to appreciate the more or less 'nicer' things in people.
wellz... that's my 2cs worth....
yes, Nismodified: lets just fooken drive our fooken ....cars, be grateful for such pleasures and love our moms!
https://www.sau.com.au/forums/topic/11759-ladder-theory/#findComment-207367
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
