well got defected last night for the following:
1) Pod Filter (only got a heat sheild around it, will wack a lid on now)
2) BOV
3) Exhaust modified no report (however it should be under 90dB)
4) Modified bonnet lid no report (CF bonnet)
5) Reverse lights not working ( got the reverse light switch indicator in my garage, need to put it in)
6) windscreen washers not working (had no fliud)
IF any1 can PM me a place to clear the defect without me having to mess aroudn taking the BOV off, or swapping the bonnet around ( i have the stocker in my garage) as i am going to melb for work halfway through next week and wont have time, it would be greatly appreciated...
Has anyone had any experience with a friendly engineer, who could do a report for my car.... preferably 1 where he could cover my bonnet, however i realise the issue with CF bonnets.
Thanx and all help appreciated :)
https://www.sau.com.au/forums/topic/117622-defected/
eeek.
Man, whenever I hear of a defect, i get scared. hasn't happened to me yet, although I did drive past a defect station a few weekends ago, on the pacific highway near the F3 of all places.
I was tucked in behind a bus, as a friendly Taxi driver flashed me a warning.
good luck with clearing it all Susp., let us all know how u go, as I'm sure I'll need the info sometime soon.
Just out of curiosity, where did it happen?
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163668
eeek.
Pennant Hills RD, coming back from an old pac run
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163671
Can't really help, but points 4 & 5 seem a little rough. Technically speaking, I guess each point mentioned could be seen as a defect, but they must have really had it in for you if they went to the effort of checking all those minor little things...
Good luck getting it all sorted.
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163674
Guys - here is the thread the club guys have used for this sort of thing
http://www.skylinesaustralia.com/forums/in...howtopic=110295
Note - if the link doesnt work then you're not a current SAU NSW member, click the link in my sig and you can download the form :)
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163721
Well its only fair that club members get the benefits - im sure you understand
Without listing names and numbers, which would defeat the point, there are several places listed with engineers on staff who can, and have helped out SAU'ers before. Price guides included.
I would tell you the names myself, but its just not fair to paying members - sorry
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163746
Haha - thats cool, petrol and mods come first :D
Can you PM me exactly what i will get? will i be able to clear my defects without havign to change parts back on my car?
will i get an engineer who will be able to sort me out with everythign i have on my car atm? including CF bonnet....
if so i may join up :)
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163801
Im not an engineer, so i cant really answer that
The thread includes names and numbers of engineers aswel as price guides, not a list of what they will pass and what they wont
Im sure when some of the members who have been through this see this thread, they will help you with specifics, but like i said.....im not an engineer
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2163809
ouch i think 5 & 6 were a lil out of line.
but if your going to get an engineers report
i highly recommend
Consulmotive Pty Ltd. 15/17-37 Lorraine Street. PEAKHURST. NSW 2210. E: [email protected]. P: (02) 9620 8475. F: (02) 9620 8475
EXCELLENT..
guys name is John he just did our pulsar..
*thumsup for him*
https://www.sau.com.au/forums/topic/117622-defected/#findComment-2164746
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
