For Sale:
11/1996 R33 series 2 GTS-4
This is your chance to own the ultimate sleeper a 4 door GTR.
It has the rb26dett, 5sp Manual and 4wd Attessa drive system. The engine conversion is top class and extremely clean.
White (pearl)
Rb26dett
5-speed man.
R32 Gtr Brake Conversion
HKS super silent exhaust stainless
Power FC with boost kit
OS Giken Cam gears
138000kms
Body and interior in excellent Condition-near new.
Very well maintained vehicle
safety Cert
Price $25 400
Please email [email protected]
Or Phone 0404 858 429
Edited by warriorbrawl
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/
GTS-4 with a GTR engine.
any work done to the engine?
engineered?
reciepts for engine/conversion? who did it?
The engine is stock aside from cam gears
I have done a compression test on it and got 165psi across all cylinders
not sure who did the conversion as it was done 2 owners before me.
Cheers
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2164142
engineered?
not sure about down there mate, but up in QLD, you can do an engine conversion, provided that the new engine was available in the same model of car, and you do the relevant brake and suspension upgrade... not sure how it would equte between a 2 door (gtr) and a 4 door (gts4) though.
i know one thing if i had a spare 30k, this thread would be closed sharpish
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2206180
Is it an R32 or R33 spec GTR motor?
GTR Brake upgrade, is that front and rear, or just front?
Does it have ABS?
Any interior pics?
Hey mate, 32 gtr engine
front and rear r32 gtr brakes
yes on the ABS
I will get some interior pics-Cheers
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2219124
Car is still up for sale
Interior pics have been added.
Just last week I had a brand new Exedy heavy duty Clutch installed by Mercury Motorsport they also changed the GBox oil to Motul and re bleed the Altessa System.
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2245564
FYI...
I have driven this car a number of times and can vouch for the fact that it is as tidy as WariorBrawl says it is.
The quality of the conversion is excellent and looks as factory as an AUTECH job.
Anyone who inspects this car would be very impreseed with its condition and performance.
Good Luck with the sale WB.
Dust....
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2265102
Would you be interested in swapping for VX SS Cmdre. Black, Six speed , 45000km, one owner, 12 months rego, Full pedders suspension upgrade and twin 2.5" exhaust. my wifes car, but ill tell her later. PM if at all interested. Regards Stuart.
No.
https://www.sau.com.au/forums/topic/117648-fs-96-r33-gts-4/#findComment-2292969
  • 2 months later...
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
