hey all, i've got some new second_hand rims and they have met with the gutter a few times - got some nice rash on the outer edge. just wanting to know if anyone knows of a place in melbourne that can do wheel repairs, and how much?? pref in nothern subs.
the wheels have a polished metal dish on the outer, that looks to have a clear coat over it. no painting would be required other than that. and they're not bent, just scraped. thanks in advance.
https://www.sau.com.au/forums/topic/117799-where-to-get-rims-repaired-in-melb/
There is a place in moorabbin I've been to for an old school centreline wheel repair. Its called something like AJAX rims or something. look em up. They specialise in steel rim repairs. The old guy I dealt with was very helpful coz I wasn't sure what needed to be done. Wasn't close to me but was the only place I could find that could do the job. (steel)
Do you know if it is alloy or steel? That will determine the repairer you go to.
There's plenty of alloy wheel repairers around. Good luck.
yeah Ajax, near where IKEA use to be
the wheels are work ryver's, they're two piece and i'm pretty sure they're alloy. if the outer rim was painted then it would be a simple sand/fill/spray job - but cos they're polished i think thats a job for the pro's.
does this ajax joint deal with alloy's?? i don't think a steel wheel place will be much use - they're not bent, just guttered.
AJAX would be no good for alloy. Plenty of them around that specialise in alloy repairs. one in moorabin that I went to first. not sure of the name.
Yeah I should've known they wouldn't be steel. It'd be sin to put heavy steel wheels on a skyline.
Try Coburg Mag Wheels. 93544641. Worked for me.
cheers fellas, got a few numbers to keep me busy. i'll get some pics and quotes and post them up to give ya'll an idea what you'd be dealing with if it is unfortunate enough to happen to you.
TIP: if u upgrade from 6" wheels to 9" wheels with similar offset, they're going to stick out a fair bit more - so remember that next time u turn past a gutter :P
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
