all parts located in melbourne, there taking up space so they NEED TOO GO. all off a r32 gtst
1- rb20 intake manifold - 150
1- rb20 exhaust manifold - 120
2-rb20 heads,complete with cams/journals, etc, suit rebuld, will seperate any parts off the head- 100 each
2- rb20 turbo auto gearboxes suit rebulid- 50 each
1- rb20 stock t28 turbo, suit rebuild-100
1- rb20 block, complete with pistons,rings,rods,crank etc. good nic, just needs oil galleriers cleaned- 250
1- rb20 afm,(same as z32) 80mm, needs new adapter plug- 100
1- rb20 waterpump, PERFECT condition, was put on the car for 2 months before motor was changed, works perfectley. 50
THEY NEED TO GO< AN OPORTUNITY TO GET GOOD PARTS AT GREAT PRICES
Edited by granca69
https://www.sau.com.au/forums/topic/117818-r32-gtst-cleanout/
rb20 afm isn't the same as z32, its the same an rb25 one
Hello!!
How much for as much of a complete engine as you can get together ie head, block, turbo and manifold, inlet manifold, as many lines as you have towards a complete engine? Please let me know how much and what I would still need for a complete engine.
Cheers!
James
PS also freight/postage to 2281 please.
hey man you wouldnt have an r32 gtst air box would you? pm me if you do
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
